maytag gemini range; First I had the ignition spark clicking and would not stop then there was a...
(More)
maytag gemini range; First I had the ignition spark clicking and would not stop then there was a burn-out smell and a little smoke and and then no spark to light burner gas still comes out but I need to light with match by hand. Could this be a burnt out spark module burnt and how to get add it/ What part do I need to replace? Many thanks!
I have a Maytag MER6771 Gemini Electric Range. When I turn on the oven, none of the buttons work on...
(More)
I have a Maytag MER6771 Gemini Electric Range. When I turn on the oven, none of the buttons work on the panel except the numbers 3,5,9 and the cancel. I have to flip the breaker to the range, wait 3-4 minutes then reset the clock and it will work. Once I am done baking an item, I can't reset the temp to a different temp without going thru the whole process again. Any suggestions?
f1-1 error code Replaced top oven sensor, when I use the bottom oven the same code. when I use...
(More)
f1-1 error code Replaced top oven sensor, when I use the bottom oven the same code. when I use ethier oven I get that code.
