Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
"Mad"-spinnig CPU's fan and turbo-sound
Hello, everyone. I'd appreciate greatly any advice about the following problem. I've had a Dell Dimension 5150 for about 2 years now, and about a couple of month the CPU's cooling fan started behaving strangely. From time to time it starts to spin as mad with terrifying turbine engine sound that one can hear when traveling on a plane. The problem is obviously intermittent (“come and go”) , and I can’t spot any pattern or regularity. It could happen after 2-3 minutes after powering the PC on, or after a couple of hours working on it. I tried the cold reboot; it didn’t solve the problem. It seems that the “mad” spinning accompanied by the “turbo” sound happens more often now.
What shall I try to fix it? I found an article about a similar problem (Computing.Net forum) , and one of the replays read that changing the fan (ordering new one from Dell) hadn’t solved the problem. Help!
  • Andy69 Mar 02, 2008
    Thanks to everyone who answered. I was away for some while, but now, thanks God, have got some time to try to sort it out.
I had the same problem,
Turns out it was completely caked with dirt
i cleaned it out and it purrs like a kitten
good luck
Posted on Jan 28, 2008
Andy,
Just repaired this prob. on my mom's 5100. You have a bad cooling fan in your power supply. This is a $4 part but to do it yourself you have to be up for some mech. dis. and reassembly. Here's the link to the part:
http://www.allelectronics.com/cgi-bin/item/CF-296/220/12VDC_80MM_COOLING_FAN_.html
You'll need to power the comp. down, remove the side cover, unscrew the power supply box from the rear, open it, unscrew the fan, remove it, clip the red and blk. wires, splice/sotter the new fans' leads to them, reinstall the fan and reassemble all parts.
Hope this helps,
Mike
Posted on Jan 18, 2008
  • 36 Answers
Have you cleaned out the machine with a good can of air to get all that dust out? Can u do anything to trigger it?
Posted on Jan 04, 2008
No video on computer and no beep indicating a problem with the video
Maybe the memory you installed is bad. I would put everything back the way it was before you put in the additional memory and see what happens. If it works, then one of the memory chips you just purchased is bad or not compatible with your model.
Apr 02, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My DELL Dimension 5150 fan is making a great noise, how can I fix it?
Turn the computer off.
Disconnect the AC power.
Remove the side-panel.
Buy a can of compressed-air, and give your computer a "blow-job" to remove dust from "everywhere", including the fan(s).
If you still get noise, then it's time to replace the fan.
Take the computer to any computer-store, so that they can sell you a new fan that matches the current fan.
May 07, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Noise from unknown source
Grrrrrrr - Could be CD running, Could be Fan on the CPU, which if not fixed will kill you main chip, could be power supply fan, check in the back and see if fan is turning consistanly ( I think that is how you spell that) If you know how to remove covers, take side off and look at fan on the CPU or other fans and when you hear the Grrrrrrr se if you can tell where it is comong fro, also some hard drives will make a sound as they get older.. Good luck....
Apr 23, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a dell dimension 5150 desktop problem; turn off after 60 minutes working.
Hi, maybe he was over heating, open your tower and look the fan of your CPU and POWER SUPPLY. Did they work? If yes, did the dirt on the heatsink of the cpu hide the heatsink? If yes clean it and make a test!
Oct 29, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension E510
A few potential problems:
1. Your CPU fan isn't working, causing your CPU to overheat and then turn off the system
2. Your power supply is faulty
3. A capacitor has blown on your motherboard
Give us more details on your problem so we can figure out what's going on
Jul 27, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can not download drivers!!
Do you have the original CD's that came with the unit? they are blue and are the recovery cd's. they have all the drivers. Also, the windows 2K and XP OS may have a compatible driver. They reinstalling that driver. or do you have a modem? If your unit didn't come with one then you can purchase one cheap and dial up to the support.dell.com
May 12, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Change Motherboard For Dell Dimension 5150
If you replace with the same motherboard that's in already, that would be easiest for you.
But if you use a different one, you'll have to re-activate Windows, and download and install new device drivers.
Jan 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
104 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
