VeriFone Magnetic Card Reader
VERIFONE OMNI 3740 INK RIBBON
posted by WILSONEYE on Jan 04, 2008
I NEED ASSITANCE ON HOW TO CHANGE INK RIBBON IN THE TERMINAL.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 21, 2008
FixYa! (100)
mbausserman
Rank:Apprentice Apprentice
Rating: 96%, 4 votes
We found that it was neither the thermal paper roll nor the thermal component. The cover did not close tight enough and that caused the print-put to be light or missing printed areas.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on VERIFONE OMNI 3740 INK RIBBON:
I don't want to Accept this solution
Best Solution
posted on Jan 24, 2008
Helpful (85)
clrprsntdngr
Rating: 94%, 10 votes
Omni 3700 series terminals (inlcuding the 3740) do not use ink ribbons they are thermal printers which use heat to effectively burn the image/text in the paper. You may be using the wrong paper (3 1/4 thermal is what you need). Sometimes the thermal component goes bad but you can get it fixed through a vendor like CDE although it may cost you upwards of $100-$150.
Thank You!
Can you Help with these Input Adapters problems?
VeriFone (M19755014US1) Magnetic Card...
I don't know how to paper feed
when I first received the credit card terminal machine, I...
we cannot print a receipt for the transaction. It just...
The product I had to choose is wrong. It was just the...
Loading problems.
Repair Service
Find Input Adapter Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
