Question about Zanussi WJS1265W Front Load Washer/Dryer
Zanussi fj1254w washing machine
Worked fine till 6 weeks ago.Then stopped. Turned out to be the motor brushes which I replaced.....On re-starting it seemed to be out sequence and would only do part of a cycle. This lasted 2-3 days then settled down and has been working ok for a month. Now it has become faulty again. Sometimes will go through a cycle but the drum does not move. Other times will start ok (drum rotates) then stops its cycle. Somtimes the pause light will come on, but pressing it will not re-start the cycle?? Any ideas/ Thanks
I have a zanussi iz16s which just does not start it goes to wash starts to fill up bit just stops on wash program and nothing goes round can any one help thanks.
Posted on Oct 01, 2008
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 04, 2008
I have a Zanussi fj1254 w. It was making a high pitched squeel when it was spinning. No when I turn it on water goes in but the drum does not turn. It turns freely when rotated by hand. i have checked the...
Possible that the drive output to the drum is not there and so there is no voltage when the cycle come to the spin mode.
Check for fault in the drive, capacitor to the motor.
Jan 21, 2013 | Zanussi FJ1254W Front Load Washer
I have a Zanussi FLS1183W aquacycle 1050 washing machine. It has stopped spinning and I suspect the carbon brushes. How do I access the motor to examine/replace the brushes?
There is no solid base to this washing machine so if you simply lie the machine on its side you can access the motor from underneath.
Jun 01, 2010 | Zanussi Washing Machines
Washing machine not working
I would advise you tcheck the filter if you have not already done so.
This should be located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
If this is o/k then could be worn brushes in motor, or a faulty motor, or control board..
This being the case, then it probably would be more economical to replace the washer.
Mar 22, 2010 | Zanussi FC1200W Front Load Washer
Grey sludge on my washing
Hi, I had the same problem.
The waste is blocked, check the drain pipe from the machine and also where it drains out to. (thick sludge)
I ended up unclipping the pipe from the drain motor (Bottom rear) and passing a garden hose throught it to flush it out.
Jan 07, 2009 | Zanussi FJ1254W Front Load Washer
Hotpoint ultima extra wma64
hiya
check the wires which run from the motor up to the main pcb, it's quite common for these to rub together and break. i have came across this a number of times now.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Zanussi FJ1254W fault
Could be almost anything....first guess...did someone lose a coin or other item?
Dec 21, 2007 | Zanussi FJ1254W Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
244 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
