Question about ASUS A8N32-SLI Deluxe Motherboard
No sound from speakers anymore
The sound from my compter stop working when i disconnect all connection from back of compter and reconnect them,the mobo sound stop working
  • 2,351 Answers
Open your controll panel & open Sound & audio devices. Click the Audio tab. Is there a audio device listed? Click on the Voice tab, is the same device listed there? Next open the System icon click on the Hardware tab than click the device manager button. Scroll down to Sound, video & game controller. Do you see a yellow ! point? If you did see a device listed in both Audio & Voice. That is OK. If you saw a yellow ! in device manager. Reinstall your audio software from youe motherboard CD. Lastly try another speaker system. If still no sound than your intergrated sound chip is defective. RMA the board through ASUS it has a three yyear warranty. You can call tech first and get a case number at 812-282-2787. Than ask to be transfered to the RMA dept.
Posted on Jan 04, 2008
Front left speaker stopped working. I use the system with my computer (full volume on computer), and usually half volume on the speaker. I've had the speaker for a few months now. I looked the wiring to...
You 'looked' at the wiring but have proven it is defective by swapping the speaker independent of the wiring. What's next? Replace the bad wiring.
What happens when you put a working speaker and wire on the front left output?
Apr 14, 2011 | Samsung HTC550 Theater System
Good morning system only sounds of front speakers and woofer i have no sound from center and back speakers
Please check the cable connections. I will suggest you to disconnect all the cables and reconnect. Make sure that you connect the jacks as per the color code.
Dec 29, 2010 | Samsung HTC550 Theater System
Speakers not working when reconnected to pc
How do I get hold of the necessary graphics driver?
Apr 18, 2010 | Logitech X-540 Computer Speakers
I got a cobra 29classic cb, little hours. i have
Set the squelch and knob to full counter-clockwise position. Turn the volume up to the 1/2 way point. Disconnect the external speaker plug from the jack. Disconnect any PA speaker plug from jack. Static / voices should be heard from internal speaker. If not disconnect the mic. Static / voices should be heard. If not, tune a different channel, sound should be heard. if not, look for indication of the radio stuck in transmit mode. If in transmit, there will be no sound until you can stop transmitting (hopefully while connected to a 50 ohm dummy load or suitable antenna - otherwise the final transistors may be blown). Reconnect accessories to determine problem component.
Mar 12, 2010 | Radio Communications
I moved and of course disconnected my computer. As I try to reconnect color to color, i get no green light and no sound. How do I reconnect?
reconnecting speakers only requiring into the single port in back of the cpu and plugging in the ac cord. Powering the speakers on. If no sound make sure port is plugged in in back of cpu, restart. Power on speakers should have sound. If not write back to clarify.
Dec 08, 2009 | Gateway Edison Computer Speakers
Drive not recognised by computer as being there
Its already time to back up your important files. Your drive is already failing.
Apr 02, 2009 | Computers & Internet
Wireless speakers AW872 transmitter won't power on anymore
I have the same set of speaker and had a similar problem. what I did was disconnent and reconnect the transceiver (sort of a reboot) and then powered everthing back up and that solved my problem.
Hope this helps
Dec 23, 2008 | Acoustic Research 900MHz Wireless Stereo...
Only right speaker working
disconnect all the cables and fix it again,then check the speaker sounds bychecking the sound settings in control pannel.
Aug 03, 2008 | HP JBL Platinum Computer Speakers
Sound gone
disconnect everything in the back of the unit. reconnect only the cd to the imputs. also,just to be sure, disconnect all speakers(label them). fire it up,play a CD, connect the speakers 1 at a time. If the 1st works you have hope ,if not, try each channel individualy.The one that reduces volume is the problem-maybe shorted cable, bad speaker,or , God forbid-Bad amp Channel. good luck
Dec 30, 2007 | Yamaha R-V1103 Receiver
ASUS A8N32-SLI Deluxe Motherboard Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
