Question about Emerson EWL20D6 Television
Setting up the TV with our stereo
We would like to set up the TV/DVD so that the sound comes from our Stereo receiver instead of the TV's sound. We cannot figure out how to do this. Any suggestions?
Sure. On back of DVD player find 'audio out" left and right.
Obtain a twin RCA jack audio cable of sufficient length and put
the two plugs on one end into those audio ports, and plug
the color matching ends into any available" audio in" left/right
ports (except "phono") on your receiver. Done.
For the TV sound use the same kind of twin cable, and obtain
the sound source from audio out left/right on the back of your
cable or satellite provider box and find one additional set
of available "audio in" left/right ports on your receiver. Done.
Turn the receiver dial to correspond to the audio port that
you selected on the back and enjoy it.
If you don't have a separate cable or satellite box chances
are your TV will have audio out left/right ports in the back
or front somewhere and use those to route your TV sound,
but if you do that don't expect the sound quality to be
top notch (depending on the TV circuitry ).
If you have only one unused audio in left right pair available
on your receiver you will need to use an "A/B" audio
switch, and your local electronic store can tell you how to
use it.
You are doing the right thing. The sound should be much
improved by using your receiver. And by the way, when the
sales person in the store suggests that you need gold plated
jacks ignore him and buy the plastic ones. They will work
just fine.
Good luck.
Posted on Jan 04, 2008
Connect roku to switch box to surround system
there must be red and white rca outputs, those are audio lines(stereo) get rca cables connect from the tv and into the AUX in the stereo amp, select aux on the amp front panel and you will get the quality sound you want,
Jan 15, 2014 | Yamaha HTR-6130 Receiver
I have a Harmon Kardon HK 3370 Stereo Receiver and a Samsung LCD LE40C530F1W. When I connect the stereo Aux jack to the LCD Audio jacks ( red and white rf cables ) I get no sound out via the receiver.
Obviously make sure your stereo mode selector is set to AUX and the volume on the stereo is turned up at least a little when you test it.
If you still have no luck then try increasing the volume on the TV as well. You may have it set so that the level of the audio signal leaving the rear output connectors on the TV varies with the TV volume. That way if your TV volume was turned down or muted when you tested it, then you would not hear anything coming through your stereo.
There should be a setting in the AUDIO OPTIONS menu of your TV where you can switch between a VARIABLE AUDIO OUTPUT and a FIXED AUDIO OUTPUT level.
With the FIXED audio output level, you control the volume of the TV audio coming through the stereo speakers with the stereo remote only.
Otherwise it should work.
Good luck.
Jul 16, 2011 | Harman Kardon HK 3370 Receiver
I have a LG47" tv
Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Audio Players & Recorders
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Best,
Mark
Jan 27, 2011 | Audio Players & Recorders
I have setup the DSP3300 hometheater. However when I play a CD, the audio comes from the front two speakers only. However there is no audio from the center speaker, rear speakers and sub woofer. Please let...
Unless the CD has DSP encoded sound, you will only get the usual CD stereo (2 speaker) sound, unless your receiver is able to apply DSP FX to a stereo source.
Oct 06, 2010 | Audio Players & Recorders
My TV doesn't have any sound with its cable. The
Tries difference setting in the SOUND setting,see how it turn out.Like setting in Variable setting,instead of fix setting.Setting in MONO setting,istead of STEREO setting.
Jun 25, 2010 | RCA 32F531T 32" TV
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Westinghouse TV no stereo
Hi my name is Roety,
I can help you with your issue ,
Why don't you simply run the cable box and DVD stereo outputs direct to the receiver. Thats what most people do. TVs do not passthrough stereo signal very well do to DHCP compliance requirements .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 11, 2009 | Westinghouse TX-42F430S Television
Surround sound for my home theater.
you cannot output sound from your xbox to another dvd system , you can however send the sound to your tv and output the signal to a stereo or home theater system if your looking to have surround sound or looking for stereo sound , the tv should be set to video1-2-3 and thats where youll be able to have sound and picture , , thanks sincerely glenn
Mar 03, 2009 | Philips HTS3400/37 System
Setting up tv sound to come thru stereo speakers
Offhand, your Philips 32PFL7422/98 do not have regular Audio Output RCA jacks (white and red), sorry. However, right before the antenna connector is an S/PDIF output connector. This should allow transfer of digital audio signals from the Philips 32PFL7422/98 to a S/PDIF capable receiver or amplifier. If you would look at the rear of your stereo and determine if it has such an input, then it would be a matter of getting the right cable/connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Philips Televison & Video
Emerson EWL20D6 Television Logo
106 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
