To view captions or text:
1. Select the desired program. Closed captioned programs are
usually marked in your local TV listing as “CC.”
2. Press CAP/TEXT on the remote repeatedly to select caption or text mode.
3. Press 1/2 on remote to select the caption or text channel.
4. To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen. I hope this helps. Thanks for using Fixya. Good luck
I know it is not the remote because the remote works on another toshiba tv that we have. Do I need...
(More)
I know it is not the remote because the remote works on another toshiba tv that we have. Do I need to replace the tv's remote sensor?
My sensor or board went out on my Toshiba 20AF45 tv. I can't access the menu. Is there a way to hook...
(More)
My sensor or board went out on my Toshiba 20AF45 tv. I can't access the menu. Is there a way to hook up my dvd player to play dvd's without accessing the aux (tv/video) button? I am also hooked up to cable and I have a sony amp hook up for sound. thanks!
My remote controls to my Toshiba TV stopped working yesterday. I have three different remotes to the...
(More)
My remote controls to my Toshiba TV stopped working yesterday. I have three different remotes to the TV, Once in a while I may get it to actually change the channel ,or turn the volume up or down. But it will only do it ramdomly and then it wont do it again. Ive reprogrammed my remotes, and changed the batteries in them, So I dont think thats the problem. Any Suggestions would be appreciated.
Thank You.
I have 2 Toshiba's with similar problems. The first one the on/off switch clicks on and off on it's own or just won't turn on. It first started with the remote then manually. I wrote it off because it was a floor model. With the other set first the remote wouldn't turn the power on or off but the volume control worked. A day later the volume didn't work either. Both work ok for now manually.
In Feb.2009, will I be able to receive TV programming via antenna or will I need a digital...
(More)
In Feb.2009, will I be able to receive TV programming via antenna or will I need a digital converter?
