I have a wireless home network with 3 computers. All of them are set to automatically obtain an ip address. 2 of the computers work fine but one will not receive the ip address from the router. I can configure the ip address manually and can see my other 2 computers but I do not have access to the internet because to do so the router must be allowed to assign the ip address.
I am also useing xp sp2 but it was working for a long while so I am at a loss as to why it begins now to act up now. Furthmore the network is working when I manually configure the ip address. I just have no access to the WAN because the router is not assigning the IP. If it were a driver problem I would guess the network would not work at all ??? Peter
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on DHCP will not resolve:
Solution #2
posted on Aug 09, 2005
Mini Me - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Guys first make sure that DHCP under services.msc is set to auotmatic and not manual. Thats the main casue of similar accounts that I have expierenced with clients. Hope that helps.
Will
Solution #4
kioner - usenet poster
Some more info from my side. I've had this type of problem on several of the network adaptors on my ThinkPad - both wired & wireless. At the office the other day, I could not get a DHCP-assigned address using my wired network adaptor. Dropped ZoneAlarm - no joy. Rebooted - same result. Refreshed the TCP/IP stack - same result. Finally got it to work by unplugging the laptop & removing the battery for 1 minute or so. (Note - the SP2 firewall is off for all cases.)
So, from my prospective, appears that SP2 is blocking responses to the DHCP server under certain conditions??
Solution #6
Grant - usenet poster
Hi guys,
Happy to know that I'm not alone with this problem.
I'm expiriencing something similar. With Win XP Prof. SP2. When I'm working at home everythings goes fine if I go outside and try to connect to another network I can not do it. I will see the other networks but after a long period waiting for the acquiring DCHP address process I obtain a Private IP address (169.162.xxx.xxx).
Other behaivior is that sometimes I'm the wireless network connection windows shows a network and says not connected and then the botton right button says disconnect.
I contact MS online support and they refer me to the computer constructor which of course refers me to MS. So "service" seems to be something used just for marketing purporses.
Regards
Solution #7
Cato - usenet poster
I am having the same problem with my Linksys card. Worked fine under XP pro SP1, but broke under SP2. According to Microsoft, the Linksys driver must be updated. But no word from Linksys of when one can expect that update.
