Question about Canon Office Equipment & Supplies
Help with changing details on Canon Fax L300
We have misplaced the instruction manual for an old Canon Fax-L300 - How do we change the date, time, telephone number and name shown on faxes
  • Anonymous Aug 05, 2008
    I need to CHANGE DETAILS of the previous owner from my CANON FAX L300, and put in mine.
    I also want to know, how I can SEND and RECEIVE fax messages.
    PLEASE HELP ME.
    HARRIS NARAN
SOURCE: Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Posted on Jan 24, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Super G3 Fax Machine by Canon
Can you get a dial tone?... check that you have pluged phone line in to correct socket and that phone/fax line works with standard phone.
Posted on Oct 20, 2007
eagle338
  • 4889 Answers
SOURCE: Canon fax/copier
1 Data Registation
2 Set
3 Set (when User Settings displayed..includes date, name etc.,)
4 Time & Date
5 Set etc..
Posted on Nov 15, 2007
leroyal
  • 2120 Answers
SOURCE: Canon MP830 - Outgoing fax dialing not connecting
Are you plugged into the LINE port of the fax machine?
Posted on Oct 21, 2008
safenude
  • 124 Answers
SOURCE: Resetting the name of company and telephone number on fax sheet
Welcome to FixYa! I'm the expert that chose your issue to resolve. Now let's get started. Office machines, for whatever reason, seem to be a lot more complicated than the ones you use at home. But, this should be an easy problem to fix. The process of putting in your required and company information is known as "registration" To complete your registration do the following:
  1. Press Function, then
  2. Data Registration, then
  3. Press set three (3) times. Your current settings will be displayed.
  4. Use the numeric keypad to enter the correct month, day, year and time in the following order: Year (enter only the last two digits), Time (use 24 hour time format i.e. 13:00 vs. 1:00, precede single digits with a zero (0) i.e 01:00) If you make a mistake press clear. Also, you can use the left/right arrows to move the cursor under just one digit and use the number keypad to change it.
  5. Press set two times. The display will show UNIT TELEPHONE, the TEL=
  6. Use the number keypad to enter your fax/telephone number (max 20 digits including spaces) If you want to enter spaces, press function, then space. If you make a mistake, press clear and reenter the number. You can also use the right arrow key to delete the rightmost digit and re-enter the number.
  7. Press Set twice. Unit will display UNIT NAME on 1st Press, then on the 2nd press a blank screen (not totally blank, it will have a cursor on the left and a A: on the right.
  8. Use the numeric pad (corresponding to letters printed on keys) to enter the company name (max 24 characters including spaces).
  9. Press Set (Unit will display TX TERMINAL ID)
  10. Press Stop/Reset to return to the standby mode.
Note: if you want to check that what you put in is what you want, you can print user data list. Here's how:
  1. Press function, then:
  2. Press report (unit will display ACTIVITY REPORT)
  3. Use up/down arrows to select USER DATA LIST.
  4. Press Set once, the list will be printed.
(information above from Canon)
That's about it....I imagine that in a busy office, it's hard to find time to read through a book just to do this stuff, but I have the time.
Thanks for using FixYa.com!
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
Posted on Jan 31, 2009
HOW TO SET DATE & TIME
To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
Press the "SET" button 2 times until you see: USER SETTINGS - 1. DATE & TIME.
To open the DATE & TIME Menu. Press SET. Use the buttons on the numeric keypad to enter the current month, day, year and current time. Just enter the new numbers over the old numbers.
To set the year, enter 08, 09, etc.
Use the 24-hours format to enter the time (e.g. 1:00 p.m. would be entered as 13:00)
You can also use the cursor buttons to move the cursor without changing a number entry.
To restore previous entry, press CLEAR. Press SET to "lock in" the Date and Time.
These instructions come directly from the User's Manual.
Hope this helps.
Mar 29, 2011 | Canon L220 Plain Paper Laser Fax
HP 920 Fax Machine - HELP
The manual is available from HP here. Hope this gets you going. Thanks for using Fixya!
Feb 12, 2010 | HP 920 Plain Paper Fax
Need a manual for a Canon Fax L300
Hi buddy,
You can get your manual from this link:
http://www.user-guides.co.uk/download/canon/canonfax/canon-fax-l300-user-manual.html
Otherwise a paid site is also there
store.payloadz.com/str-asp-i.198502-n.Canon%20Fax%20L300%20User%20Manual_Other_Files_1.
I hope this will help you. Plz vote for me
Thanks.
Sep 25, 2009 | Canon Office Equipment & Supplies
How to set the date and time
Below are instructions for changing the Date and Time for your machine. At the end, you will find a link for the owners manual for the 2060. Best of luck.
Greg
Entering the Date and Time
Follow these steps to enter the date and time.
1. Open One-Touch Speed Dial panel.
2. Press Data Registration.
3. Press Set twice.
4. Press Set again, then use the numeric buttons to type in the correct
date and time.
Use the MM/DD/YY format for the date and use the 24-hour
clock for the time, so 2:30 p.m. would be 14:30, for example.
5. Press Set to save the date and time.
6. Press Stop to return to standby mode.
http://aaabusinesssystems.com/pdf/_2060_Users_Guide.pdf
May 29, 2009 | Canon LaserClass 2060 Fax
Change date time on Schiller AT2
Press ALT - 9 - 1 - 1. This starts SETUP. U should b abble 2 change date/time.
Mar 09, 2009 | Medical
I have Canon Multipass fax C2500 Have misplaced instruction book Please advise how I can reset the date and time Thank-you Don Walter- E.F.Walter Incdonwalter@sympatico.ca
The manual is available for download here. (It takes a while to show up, as it is a large manual.) Step by step instructions for setting up date, time, and other user settings in Chapter 3.
Apr 18, 2008 | Office Equipment & Supplies
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon mp 530 fax
All in one fax MP530
Fax will not work.Memory full.How to empty memory?
Thanks
Nov 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Change Date/Time on Canon Fax L350
Left the flap on the right hand side of the fax machine.
Select Data registration
use the down arrow
1. Data registration
SET
1. User Settings
SET
1. Date & Time
SET
Enter date or time
SET
Nov 16, 2007 | Canon FAX-L350 Plain Paper Laser
Time and date
This looks like the UK version of the Canon 730. Look in the manual but as I recall, Press data registration and then set scroll down to time settings and press set and scroll down to time and date and set. Enter new time and date and set. Press stop to goto standby
Apr 26, 2007 | Canon FAX-L1000 Plain Paper Laser
179 people viewed this question
old marine
old marine
