Question about LG LSC121PMA Split System Air Conditioner
Lennox heat pump shuts down every 2/3 days
After running fine for a couple of days the unit will not come on until I press, what I believe, is the compressor reset button.
  • cmccall Jan 06, 2008
    I have to constantly hit the reset button and unit continues to shut off
  • mdgalvin Feb 14, 2009
    where is the reset button located on the lennox air conditioning/heat pump systems?
  • 619 Answers
Hi , you may use amphere meter to detect whats goin on to the compressor and component.
Clamp one compressor wire if register exceed the laber amphere of motor motor are stuck or burn/
If not register the clamp meter check the thermal control might burn or lost contact.
Posted on Jan 12, 2008
Lennox MS8 heat mode never shuts off
Is it the blower that doesn't shut off or the heating unit?
Nov 08, 2014 | Heating & Cooling
Lennox troubleshooting
Your control may a defected relay to the blower under heating mode. If that is the case you will need a new control board or replay.
Feb 05, 2014 | Heating & Cooling
Overheat errors
possible temp sensor bad if ok bad control board
Feb 25, 2013 | Balboa Instruments BALBOA VS500Z PUMP ,...
Lennox pulse 21 startup issues .does not engage fan and complete heat cycle every time .
Have seen a rash of faulty blower time delays in lennox equipment. Lennox has a recall on one currently, not sure if your system is effected but it can be bypassed if in fact the problem.
Aug 23, 2017 | Heating & Cooling
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Defrost Cycle Problems with Heat Pump
It's a defrost board issue. The timer on the board or something similar is hanging up. Unfortunately the solution is to replace the board. By lowering the temp. on the T-stat you are resetting the timer on the board. As you see that only works until the next cycle.
Feb 22, 2009 | Weather King 12AJA4801AH Air Conditioner
That's what a heat pump does. The problem to me sounds like you don't have a big enough heater inside.
Apr 30, 2017 | Weather King 10AJA4201AH Air Conditioner
You need to replace the defrost board and sensor
Nov 21, 2008 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
736 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
