Your desktop will have PCI slots for this purpose they are normally white in color located inside and mounted parallel to each other.
If your router is located near your desktop (2meters) I suggest an Ethernet Patch cable this will give you 100MB uninterrupted connection speed to your router this is the best method.
If you want to go wireless you can buy a PCI Wireless NIC card or go for a USB Wireless option, this will connect at 54g or (54MB) and requires the use of a WEP key most Branded routers have this setup within the admin control panel connected via your browser normally 192.168.0.1. Some wireless adpaters will allow 108MB connection twice the normal but you need to correct router to achieve this double speed.
I suggest that if you go Wireless then use the NIC own connection software and disable the Windows Service using this http://rapidshare.com/files/260751524/Disable.WZCSVC.reg as this can give you problems with disconnection built into the service
If you are going wired the use this reg tweak anyway you don't need it taking up your precious resources if you go wired I also suggest tha you turn off Hiberation on your Desktop using these two toggle tweaks http://rapidshare.com/files/295436075/HIBERNATION_Tweaks.zip as this is also not required for desktop use.
Lan Card commonly called the NIC is installed on most of the computer. You might have one but may be you need the drivers to get it work. Let me know what is the model of you computer. If you do not have the NIC card you can buy either the PCI Network card or also you can find the USB Network card for you to be able to connect to the Internet.
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 4600 PC Desktop
cd rom not working error code 19 acording to device manager .this is on acer aspie x3200. it will...
(More)
cd rom not working error code 19 acording to device manager .this is on acer aspie x3200. it will not run a dvd or cd on windows media player . have set all defaults to windows media player
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. ...
(More)
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. I've tried using a repair program but it says the C: partition1 is unknown and cant use this area.
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm...
(More)
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm pretty sure it freezes. What should I do?
