Question about Epson Stylus Photo 1290 InkJet Printer
Epson stylus 1290 - machine locked up
Computer tells me there is a foreign object in machine. I removed top but could see nothing jamming it. Green and red lights flashing alternately.
  • JK71 Jun 06, 2008
    Hi, we have the Epson Photo Stylus 1290, running on Mac OSX. The Utility message reads Communication Error. The weird thing is the inks will not slide across, does this sound like the ink pads are full or something else?
    Thanks, Julia.
You can download the repairer's manual for free from http://pcprinter.blogspot.com/2008/05/service-manual-for-epson-89012801290.html  which is where the solution below is listed (p.68).
Basically Epson want you (or, rather, a service centre which you'll have to pay!) to replace the waste ink pad every so many copies. However, you can reset the printer even without replacing anything by switching it off on the silver button, switching it on again whilst holding down the two black buttons alongside it, then releasing them all before quickly holding down just the left-hand black button for 10 seconds. You have only three seconds to do this after switching back on, whilst the green and red lights are flashing together. If you're not quick enough on the first try, switch off using the silver button and repeat the procedure!
Posted on Mar 07, 2009
  • pbee Apr 04, 2011
    Fantastic! It worked. Thanks a million. That's saved me a few hundred quid. I was thinking I would have to buy a replacement. Just one thing - this appears to be a work-around for replacement of the waste ink pad, and I'm wondering whether I'm storing up problems for the future by not replacing the waste ink pad. If it's easy to replace the waste ink pad then I feel i should do so, but I don't know how to do it or where to obtain a replacement. Any suggestions?
  • 353 Answers
I am a PC person rather a Macee. However, if your printer had full waste ink pads, both printer lights would be flashing. You say "The weird thing is the inks will not slide across", they shouldn't manually, unless you release it from the interlock. Now, a communication error can be caused by a number of things:
1. Check the USB cable is properly connected both ends. Check it further by using another cable.
2.Check your USB ports are OK - plug something else in, like a flash menory stick to confirm it works OK.
3. Check your printer is properly installed by uninstalling it, rebooting then re-installing.
4. Maybe your OS is corrupt. This is not too uncommon with Windows (an OS re-installation will fix), but I don't know about Macs.
Posted on Feb 01, 2009
My Epson Stylus Photo RX 600 had been working fine until yesterday, when I tried to use it it wouldn't print or scan. It says "Cannot read memory card or storage device" All the wires are connected and...
when the machine is powered off and power cable has been removed, try removing all dust and foreign objects from the card reader with compressed air. disconnect all unnecessary cables and retry the print/scan job. if this doesn't work, either the card reader or the system board is defective (most likely the card reader)
Sep 27, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
I have an Epson Printe RX 420 and now an E has appeared while the green lights go on and off. What to do? many thanks, Yvano
power off printer.check for obstructions/foreign objects. remove obstructions/foreign objects. power on printer.
Jul 06, 2010 | Epson Stylus RX425 Multifunction...
My 1290 fails to feed the paper. It seems that most of the time the paper is picked up at one edge so the paper crumples
When you experience damage to the paper when feeding it means that it is hitting something in it's path. Open the printer and check the path of the paper for any foreign objects like torn paper, staples,and the like. And if you have printed any labels, part of the label maybe caught on one of the rollers.
May 18, 2010 | Epson Stylus Photo 1290 InkJet Printer
When the Epson C87 stylus printer is about to print, it makes a high pitched scream and doesn't print. The 2 left hand red lights flash quickly and simultaneously and the green light does not show. The...
Hi
I think maybe it could be that your ink cartages are slipped on the thin belt that moves them from one side to another or it stuck or belt come off take a look and see it the ink will slid from side to side you can do this by hand but don’t push them to hard, that what it sounds like to me it worth a try.
All Best: Pineworks
Jan 24, 2010 | Epson Stylus photo C87 InkJet Printer
Epson Printer NX400 series problem
Found this on the web. You can download the
manual, reference guide, troubleshooting guide and more. Hope this helps. If you find this helpful, pls rate. me.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&infoType=Overview
According to the error codes :
Make sure there's no jammed paper or other obstruction inside your Epson Stylus.
The print head may not be able to move because of some obstruction. Follow these steps to remove jammed paper or other obstructions from the Epson Stylus:
Turn off the Epson Stylus.
Open the scanner.
Remove any jammed paper or other obstructions from the paper path.
Carefully lower the scanner.
Turn the Epson Stylus back on.
Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Epson Stylus.
Good Luck............
Jan 22, 2010 | Epson Stylus NX400 InkJet Printer
Error E-90
error E-90 means that something is stopping the ink carriage from moving its full extent. Open the scanner and check that the ink carriage lid is firmly locked down, check along the path of the carriage for any foreign/loose objects. Use an alcohol wipe or similar & gently wipe the plastic registration strip that goes through the top rear of the ink carriage. Be careful not to dislodge or damage it. If the carriage moves when you switch it on, pull out the power cable when it is across to the left and check for loose gears or foreign objects in the gears on R/H side. Hope this helps.
Apr 20, 2009 | Epson STYLUS CX5900 Printer
My Epson Stylus DX5000 won't work. All the lights are flashing and my comouter tells me to open it up and remove the "foreign" object. I can't see any foreign object and can't see hoe t open it up other...
i had the same problem and checked for paper jam but wasnt any so i kept turning on the printer while looking in side and found that one of the little white cogs where the ink box rests wasnt catching when i pushed it into place the printer set itself and started working maybe you could try this. good luck.
Feb 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson 1290 Printer
Yepperz... Here is your fix
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 21, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
522 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
