Printers
Generic problem for all Printers
HP printer problem
posted by cmcdaniel on Jan 04, 2008
HP buisness ink jet 2800. Says close covers and all covers are closed. Any ideas?
Thank you
Cameron
Comment posted on Jan 04, 2008
I don't work on printers very often so any help would be great.
Thanks
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 12, 2008
Thanks for Trying (70)
Altini
Rank:Wiz Wiz
Rating: 85%, 91 votes
The pin on the cover do not simply push the arm, instead 'slide' it in some manner. Try lubricating somehow the arm inside hole or the pin, allowing to slide with each other !
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HP printer problem:
I don't want to Accept this solution
Solution #2
posted on Jan 11, 2008
Not Rated (0)
silentspoon
Rank:Guru Guru
Rating: 89%, 117 votes
The large top cover has a small pin on the right side that fits into a receiving hole on the top of the printer. The pin pushes down an arm that deactivates the 'open cover' sensor. Your pin is not pushing the arm down. This can happen for a couple reasons, one, the pin could have sheared off (you won't see the pin at all, or the pin is no longer long enough), or two, the pin is not seating in the hole properly.
If not seated properly, you can realign the cover, and ensure the pin is seating into the hole. If the pin is no longer long enough to actuate the arm, simply fasten the sensor end of the arm to the contact in the top of the printer. You can use a hot glue gun, or even tape.
Thank You!
Can you Help with these Printers problems?
Dymo LetraTAG Thermal Label Printer
how do i fix error 1
Printers
My canon printer pima mp210 the alarm button is on and...
HP Photosmart 7850 InkJet Printer
your a ***! 19.99?
Canon PIXMA MP150 All-In-One InkJet Printer
The error code is for paper jam, but really there is no...
HP DeskJet 840c InkJet Printer
how to make an anvelope on printer hp 840c
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
