Sony Cyber-shot DSC-W100 Digital Camera
Problem for Sony Cyber-shot DSC-W100 Digital Camera
When I switch the camera on, the shutter opens and
By daniell_diam on Nov 04, 2009
When I switch the camera on, the shutter opens and the zoom extends out, but then repeats these actions several times, as if it is confused, and then tells me to turn the camera off and on again. After doing this, the same happens.
Solution #1
posted on Nov 04, 2009
Not Rated)
StephanSA
Rank: Guru  Sony Cameras & Camcorders  Expert
Rating: 93%, 186 votes
Hello
This either means that something is jamming the lens , or that the lens sensor is faulty. This is a very , if not the most common problem with modern digital camera's.
Most of the time the problem is that sand , dirt and grit gets lodged in the camera lens barrel thus keeping it from extending properly but could also be caused by a drop or a hard knock on the camera.
Firstly , the odds are not with you on a DIY fix so don't be disappointed when the following steps do not work.Nevertheless , some people have fixed their camera's using the following steps.
Use these at own risk as it may further damage the camera.
Firstly try charging your batteries overnight and then try the camera again tomorrow.
Try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
These 3 options provide your camera with more power available to the extension mechanism which could overcome some of the particles that are lodged in there if there are any.
Try using compressed air (best is a clean air can bought at a electronics store) and blow between the lens and the casing. This should help dislodge some of the particles.
Look at the lens , and if some of the lens 'circles' are misaligned or not concentric then try wiggling it (while holding camera lens down) so that some of the particles can escape. Also try moving the lens away from the side with the biggest gap (also upside down)
Try gently pushing or pulling the lens when it tries to extend but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
As a last resort if you decide to replace the camera try hitting the camera near the lens with increasing force with the palm of your hand. Between each hit , try using it again.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise works. Good luck and don't hesitate to contact me if you need further assistance or information.
Regards
Stephan
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-shot DSC-W100
Questions and Unsolved Problems for Sony Cyber-shot DSC-W100
Do you recommend Sony Cyber-shot DSC-W100 Digital Camera?
Answer
Answer
Would you be able to tell me how to replace the lcd screen? Mine fell and the screen cracked,... (More)
Answer
When I'm viewing pictures the all the different exposure types start flashing on the screen and then... (More)
Answer
I have digital camera and pic phone. no printer. i want to download to computer but dont know how. i... (More)
Answer
Front lens doesn't always open/close when I turn on/off the camera. Sometimes it does half way.
Answer
The lens on my camera is stuck. I dropped it. The lens will not move.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Cyber-shot DSC-W100...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
