Question about Sakar Black Wireless Optical Mouse (021331700506)
Keyboard works, but mouse does not
Hi, when i installed the keyboard it worked right away....but the mouse does not. what am i doing wrong???
You need to reenstal your soft wear for moues
Posted on Jan 04, 2008
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
Mouse never wokred the computer says device is working properly it DOeS not work
Usually they work as soon as you use the cd and install it. You do need the right driver for the operating system you're using. If you don't have the install for the operating system search for micro innovations site and download it, usually under their support section.
Also double check the connections and make sure that the antenna isn't too far away from the mouse. It won't work if it is. Try moving it to another place and see if it works then.
If none of that helps then perhaps you have a defective mouse.
Jun 25, 2011 | Micro Innovations PD7250LSR Wireless RF...
Wireless key board & mouse
  • Decide where the keyboard will be placed, whether it is on your desk or a table. Spend a little time experimenting with positions and placement to make sure your wrists and arms will be comfortable. You should consider ergonomics before you set up the keyboard to avoid repetitive motion injuries later on.
  • Step 2 Install the batteries (usually three AA) in your wireless keyboard. Replace the cover securely so the batteries are connected properly. Turn the keyboard on.
  • Step 3 Get out the wireless receiver that came with your keyboard. Position it close to your computer, but not closer than about 8 inches, as the computer itself can cause interference with the wireless signal. You will also want to set the receiver away from other interference-causing devices, such as radios, TVs and telephones.
  • Step 4 Ensure that your wireless receiver is no more than about 6 feet away from where you plan to set your keyboard.
  • Step 5 Insert the CD containing the accompanying software into your computer. A dialog box should appear on your screen. If the install instructions don't pop up right away, manually access the CD by double-clicking its icon or selecting it from the Start menu.
  • Step 6 Plug the wireless receiver into a free USB portmag-glass_10x10.gif on your computer. If you don't have any ports remaining on your computer, you can use an external USB hub instead.
  • Jul 07, 2010 | Dell Wireless Keyboard Optical Mouse w0147
    All in one computer and mouse and keyboard are not responding.
    Check your keyboard is working or not by accessing your BIOS by pressing del or Esc or F12 (usually) or whatever your boot up screen says. If your keyboard works there then the problem lies in the operating system.If still your keyboard doesn't respond then replace the keyboard.
    only if keyboard work, you can fix mouse opearting system problems.
    For windows Vista & 7, expand "Mice & other point devices".right click on Microsoft Ps/2 mouse" select uninstall and restart the system.If your mouse is still working the system will automatically installed the mouse driver.And your mouse will work again.
    Otherwise get a new mouse.
    Note: Check you have wrongly insert the mouse 7 keyboard port at the back too.
    Remember : Green for Mouse
                       Purple blue for keyboard
    Dec 22, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
    Cordless access duo, mouse won't work
    please go on control and look mouse setting and correct it. and also look battery of mouse, if not work there is hardwere fault. (nepal)
    Jul 11, 2009 | Logitech Wireless Access Duo Optical...
    Wireless keyboard wont work
    check that youhave installed the keyboard correctly , for that to do first press the receiver signal button then press the button on the keyboard which will be connect.....
    Jul 04, 2009 | Logitech Cordless Desktop EX110
    How to make logitech keyboard & mouse work??
    Hi there: I was also facing the same problem. But when you see on back of the keyboard the instructions are there. or follow these steps.
    1. insert new batteries both in keyboard and mouse. 2. decide what device you want to connect 1st (Lets connect Keyboard first) 3. Pres and Hold the connect button for both key board and receiver for about 5 secs. 4. don't press any key on key board till 10 secs (During this time it trying to connect with receiver) 5. Check the key board connectivity if it works then take it away or put it behind some barrier so that when you are connecting the mouse it don't interrupt. 6. now for the mouse do the same process as you have connected the keyboard.(step 3 & 4) 7. now check both key board and mouse they will work fine. Thanks
    Sep 21, 2008 | Logitech 967461-0403-PK Keyboard/Mouse
    Computer not recognizing Keyboard, only Mouse
    I'm having the same problem. Mouse works great but the keyboard doesn't. I've uninstalled and reinstalled the software at least twice via remote desktop- done a hard reboot on the hardware (it's a Logitec wireless keyboard) - I've even tried installing it on another computer and the keyboard and mouse both work great! I just can't get it to work on my computer. The curious thing is that the side buttons (like sleep work) but it won't Ctrl Alt Del so I can login - what am I doing wrong? Are there settings that need to be changed?
    Aug 17, 2007 | Sakar 62150 Keyboard
    It doesn't work after turn off the computer
    There is usually a button you have to press, right under the keyboard and the mouse. Pressing that will connect it with it's station. And also, don't put the station too far away.
    Apr 05, 2007 | BenQ X805 Wireless Desktop Companion Pro...
    Sakar Black Wireless Optical Mouse (021331700506) Logo
    69 people viewed this question
    Top Sakar Computers & Internet Experts
    micky dee
    Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
