Question about Acer Aspire 5100 Notebook
Error in connection with camera
A remarks appeared:
another program/application was been using the camera.
but i haven't even open anything except for the the orbi cam itself.
even i select the switch and retry button.
  • zayani Jan 04, 2008
    i have a acer aspire 5100... my usb ports are like almost dead... sometimes when i check the property of my computer it works.. but after that it show the zip/rar files are corrupted while trying to open..... also have problem with cam driver cant install. from - zayani ahmed
    Sergeant:
  • 263 Answers
You can select the program that will open your cam by clicking with the right botton mouse and select the program you wants to use or browse if tue program is not on the list and click on the blank box for allways use this program......this is for bongceb ,,,,,,,,,,,,,,,,,,,,,,and for zayani you may have virus on your computer do a scan to your system and get the drivers from http://www.driverguide.com
Posted on Jan 05, 2008
6ya staff
SOURCE:
Connection error
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Feb 01, 2014 | Canon PowerShot A710 IS Digital Camera
When I installed google chrome again an error appeared naming "the application was unable to start correctly (0*c00000a5). Click OK to close the application". I uninstalled it becuase the same...
That seems to happen when people mix 64-bit and 32-bit environments; either you're using RunAs in a weird way or the Intel exception BAD_IMPERSONATION_LEVEL (which you got; it's not about you, though) is your particular installation of Windows' way of whining that MSIE should be tops on your list. Maybe you need to pick a different version (e.g. 32bit) of Chrome...usually if you install on the same machine you downloaded chrome by (from chrome.google.com) you should be fine, though!
It's pretty logical for a program you uninstalled to not run anymore, on the other hand. You get to reinstall chrome from a new download and see if things improve.
May 23, 2011 | Computers & Internet
When I try to open 'My Comupter' from the desktop or anywhere else for the matter I get the message Windows Explorer has stopped working, and two options 1. Check online for a solution and restart the...
Easiest way to fix that problem is to save all your important files onto an external hard drive and reformat the hard drive, otherwise you will be trying to correct this with Antivirus programs and other junk that will only cover up the error message. Alot of times it is easier to format and reinstall the operating system than try to figure out tose error codes, and windows never gets their stuff right.
Good luck.
Jun 12, 2010 | Microsoft Windows Server 2008 Enterprise...
Asus Webcam constantly being used by mystery application
Built in webcams are not the easiest to troubleshoot as its difficult to reboot the webcam software.
With my plug-in I can just disconnect it for a couple of seconds to reboot it and clear the previous program.
Its not unusual for webcam software to remain hooked up to a program even after you exit it correctly.
What is unusual with yours the webcam comes on when you start your computer.
You might try to disable your webcam and then enable it again in the 'Imaging' folder of your Device Manager to see if the webcam light goes off and remains off when you enable it again.
You should be able to see where the webcam is being used by launching your Task Manager and hitting the Application tab.
Hope you can get your problem sorted and post some information on it for future reference
Dec 06, 2009 | Computers & Internet
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 20, 2009 | RIM BlackBerry 8800
HP KQ246AA 8.0MP Deluxe Webcam not working on skype. It keeps saying there is a video error-the video might be in use by another application or program. Except there isn't any other application that is...
Sometimes webcam software can still be hooked up on a previous program where it was being used, even if the program was correctly exited.
Just reboot your webcam software by unplugging the webcam from the USB port for a couple of seconds
Re-check your settings
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your webcam as the default microphone. ( If it has a built in mic )
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your webcam as the default Webcam.
  7. Click Save.
  8. Test LifeCam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site: http://support.skype.com (http://support.skype.com)
Sep 16, 2009 | HP KQ246AA Deluxe Webcam
Close the other video streaming application to start video
Your camera is already online. Double click the camera icon in the lower right task bar and it will work. That is the problem, the program is trying to run twice. Again, the camera is online and working and the access to it is in the task bar at the bottom. You, of course, can change these setting if you like.
Jun 21, 2009 | Dell Studio 1737 Laptop
Webcam not working 5520laptop,shows not connected My aspire 5520 came with Vista, was running extremely slow. Installed XP and everything's working fine now except the webcam. I've tried every driver on...
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%205520.pdf?CFID=2214079&CFTOKEN=50862842
I suggest you install the web cam application as well as the drivers. Also the Acer empowering application needs to be installed. You can click on the link supplied to see all of the applications and drives for your model.
Hope this helps. You can get additional help on the website Notebook forums and discussions site.
Mar 23, 2008 | HP Pavilion dv6000z Notebook
Visual Basic 6.0
1. IDE is Integrated Development Environment
2.With VB 6, one can develop applications with feature rich GUIs (Graphical User Interface). Many varieties of general purpose software can be created with little effort, including, but not limited to, image editing software, text editor and database applications.
3.Windows Application Template
Used to create Windows-based applications that run locally on users' machines. You can build anything from a simple single-window tool like Windows Calculator to a complete application with multiple windows and advanced capabilities.
Class Library Template
Used to create reusable classes or components that can be shared with other projects.
Console Application Template
Used to create command-line applications, programs that run from a Windows command prompt and have no visual interface.
My Movie Collection Starter Kit Template
Used to create the pre-built My Movie Collection sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
Screen Saver Starter Kit Template
Used to create the pre-built Screen Saver sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
4.FormShaper lets you change the shape that windows draws your forms. You can have rectangles, rounded rectangles, ellipses, polygons and any combination of the above! Even save the shapes to a file for use in other projects! See readme.txt in the zip file for more details
5.Description
Used at script level to force explicit declaration of all variables in that script.
Syntax
Option Explicit
Remarks
If used, the Option Explicit statement must appear in a script before any procedures.
When you use the Option Explicit statement, you must explicitly declare all variables using the Dim, Private, Public, or ReDim statements. If you attempt to use an undeclared variable name, an error occurs.
Use Option Explicit to avoid incorrectly typing the name of an existing variable or to avoid confusion in code where the scope of the variable is not clear.
Feb 20, 2008 | Computers & Internet
Camera won't start "Another Application is running"
Dear Friends,
I have the same problem (Application is still running close it and start the camera) from last Week onwards, i went to the sony ericson service station, they told some Part(board) to be replaced and It will take 15days hardly,I dint accepted his comments, Then i worked full fledged on this and i got the solutions,
Solution:1(model:W580i)
*Remove the memory stick and push the air (from mouth)into the Inner camera.After that it will work Fine.
Reason: If Dust in your camera lens, the error will appear, so it is a matter of sensor.
Solution :2
* Observe the problem little closer, and fix it, b'coz you know your mobile very well than the 3rd Person.
Solution:3
Throughout all the mails regarding that error messages using Googles Search
Don't go Mobile service stations without knowing a nature error, because they ready to cheating us. Becareful.......... Freinds
Any queries,
Call me on my hand phone:
My Number: 9940097172
Rgds.,
Nagoor
Jan 20, 2008 | Sony Ericsson W850i Cellular Phone
Acer Aspire 5100 Notebook Logo
35 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
