http://www.mediafire.com/?my8yixkyhho here yopu gonna find drivers for xp on this model ...the sound driver too probably .... anyway ...when you will try to install the driver ...and its the right one ...it will find the device automatically ....if not ...just run the add new hardware wizard located in the control panel ...this will find any hardware on your computer that is on butr not installed....after you locate it ...run the automatic installation if you already installed the driver to fit it on the issue ....if you do not installed the driver yet ...browse to guide the wizard to the driver location or to the disk if you have it on disk ...I just assumed that it do not locate the device cause you didn't got th e right driver for a cause either you changed the original OS or just upgraded the hardware
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
Router won't reset and is not pingable. When reset and re powered up, all the lights are green...
(More)
Router won't reset and is not pingable. When reset and re powered up, all the lights are green immediatley (except wireless) so not going through any boot up.
I've been on a Dell XPS system and bought an IMac. During setup of the IMac I cannot find the router...
(More)
I've been on a Dell XPS system and bought an IMac. During setup of the IMac I cannot find the router nor remember the password. Any suggestions?
when the router stopped working the dsl light and the internet light were green but the power light...
(More)
when the router stopped working the dsl light and the internet light were green but the power light went to red
