Sony P6-120MP 8mm Tape
8mm Tape stops when rewinding
posted by gcorbin on Jan 04, 2008
I have a Sony 8mm camera that works fine with most tapes. A few tapes stop when rewinding in the middle. I also have a tape that will play forward and rewind only to a certain point (not the beginning of the tape). The camera thinks it rewinded to the beginning because the tape icon shows full. Is there a way to rewind it to the beginning?
What would be the cause of other rewinding problems? Is there a place that I can send these to, to get fixed and/or fixed/transferred to DVD's?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 12, 2008
Not Rated (0)
TBlessed 1
Rank:Guru Guru
Rating: 89%, 17 votes
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 8mm Tape stops when rewinding:
I don't want to Accept this solution
Can you Help with these Audio and Video Media problems?
thank you for your quick reply, i would like to ask if the...
Where can I get a download user manual for Voice Trek V-13...
I had issues trying to get the mp3 player to install what...
I have a 2005 Sony digital camcorder with a Carl Zeiss...
Hi, I have 10 tapes and about half of them when you play...
Loading problems.
Repair Service
Find Audio and Vid. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
