Question about EliteGroup K8M800-M2 Motherboard
RAM not running at full speed
Hi:
I have a K8M800-M2 (PCB 1.0) that I've built up myself. I am running an AMD Athlon 64 3000+ CPU and 2x512MB of PC3200 RAM. My BIOS version is 1.1c.
My problem is this:
My RAM is running at 166 MHz (2667 Gb/s) even though the FSB is being driven by the CPU at 200 MHz (CPU multiplier is 10x and FSB is 200 MHz, resulting in a CPU frequency of 2000 MHz). Both the BIOS and AIDA32 report that the RAM is running at a slower frequency.
How do I speed up the RAM to run at its full 200 MHz speed?
    President:
  • 2,351 Answers
Go to page 33 in your manual, see DRAM Clock/Drive Control & press enter. You can tweak your memory to run faster however your manual suggest not too. Hate to see you burn it up. As you will see everything is set to Auto:
Max Memclock (Mhz) [Auto]
1T/2T Memory Timing [Auto]
CAS# latency (Tcl) [Auto]
When DDR Timing Setting by is set to Manual, use this item to set the DRAM frequency. Would be nice to have a side panel fan blowing on your memory.
Link to your board.: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=455&DetailName=Specification&MenuID=1&LanID=9
Posted on Jan 04, 2008
Upgrade HP Compaq Presario F750US - CPU, GPU & RAM
You'll spend more money trying to upgrade this laptop then it would cost to just buy a better used one on eBay. Probably even spend more that it would cost to buy a new low end computer. Save yourself the headaches and time and buy a NEW laptop.
Jun 13, 2012 | HP Compaq Presario F750US
The AMD xp1500 processor is slow. Its need to be faster than it is. Need to know. Cheers!
If your computer has less than 512MB of RAM, then that is one "bottle-neck" that hurts your computer's overall performance.
Consider adding 512MB or 1024MB of RAM.
Or, your motherboard probably will accept other AMD processors in the "Athlon XP" line. Take your computer to a computer-store, and see if they can sell you a '2600+' or '2800+' AMD CPU that will be compatible with your motherboard. That upgrade will make your CPU almost _twice_ its current speed.
Oct 22, 2010 | AMD Athlon XP 1500+ , 1.33 GHz Processor
How to get AMD athlon 3700 socket 754 engineering sample cpu run at proper speed
Here's a little history
http://compreviews.about.com/cs/pchardwarebasics/a/aaBIOS.htm
More advanced stuff
http://compreviews.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=compreviews&cdn=compute&tm=128&gps=215_11_1267_540&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=2&bt=0&bts=0&zu=http%3A//www.adriansrojakpot.com/Speed_Demonz/BIOS_Guide/BIOS_Guide_Index.htm
Some systems have "bottlenecks," where small overclocking of a component can help realize the full potential of another component to a greater percentage than the limiting hardware is overclocked. For instance, many motherboards with AMD Athlon 64 processors limit the speed of four units of RAM to 333 MHz. However, the memory speed is computed by dividing the processor speed (which is a base number times a CPU multiplier, for instance 1.8 GHz is most likely 9x200 MHz) by a fixed integer such that, at stock speeds, the RAM would run at a clock rate near 333 MHz. Manipulating elements of how the processor speed is set (usually lowering the multiplier), one can often overclock the processor a small amount, around 100-200 MHz (less than 10%), and gain a RAM clock rate of 400 MHz (20% increase), releasing the full potential of the RAM.
AMD also produced x86 designs which competed with Intel on performance rather than price. In January 2002 the Pentium 4 gained a lead in sales and AMD marketing responded by giving their processors numeric suffixes approximating the clock rate that an AMD Thunderbird (and by inference a Pentium processor) would need to give matching performance, openly undermining the "megahertz myth".
May 15, 2009 | Computers & Internet
Bus Speed 200mhz instead 1000mhz
PLEASE INDICATE WHAT IS YOUR PROBLEM....
Jan 08, 2009 | ASUS M2N-E Motherboard
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Playing CRISIS..
heres more info on the game
http://en.wikipedia.org/wiki/Crysis
Operating System - Windows XP or Windows Vista
CPU Minimum - 2.8 GHz or faster for XP, 3.2 GHz or faster for Vista
cpu Recommended - Intel Core 2 Duo @ 2.2 GHz, or AMD Athlon 64 X2 4400+
Memory - 1 GB RAM for XP, 1.5 GB RAM for Vista
Recommended - 2 GB RAM
Hard Drive Space - 12 GB of free space
Minimum Graphics Hardware - 256 MB video memory, NVIDIA GeForce 6800 GT/ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater
Recommended - NVIDIA GeForce 8800 GTS 640MB or ATI 2900XT 512MB
Sound Hardware DirectX 9.0c compliant card
Jun 16, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
Can't install a driver
i've lost my driver cd for my asus wl -167g, can i download it for free?
Apr 03, 2008 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
EliteGroup K8M800-M2 Motherboard Logo
326 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
