Linksys WRT300N Wireless Router
Acquiring network address
posted by Priscilia on Jan 04, 2008
it just disconnects n shows not connected,when i troubleshoot it shows acquiring network address.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 12, 2008
Thanks for Trying (70)
itesonline
Rank:Master Master
Rating: 83%, 34 votes
From the PC you are trying to connect to your wireless router LAN there are two possible causes of these problem.
1. No DHCP Server Available.
2. You are using MAC Filters and the MAC is not defined in the router configuration.
Please verify this and you can easily get through it.
DHCP can be configured over your wireless router also incase you don't have DHCP Servers in your LAN / WAN. Other wise you can go for manual IP addresses.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on acquiring network address:
I don't want to Accept this solution
Solution #2
posted on Nov 08, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Try the simple stuff first. I had this same problem and it ended up being that I had my caps lock pressed when I setup the WPA shared key on the router. I was entering the wrong key on the laptop because caps lock wasn't pressed. If you are using WPA security and you enter the wrong key, the behavior will be that it keeps trying to acquire a network address. In the system tray, the indicator "flashes" momentarily and then tries to reconnect.
The easiest way to see if it's a security problem is to momentarily switch to a different security protocol (WEP from WPA) or even disable security and see if you can connect (leave mac filtering on). If you can connect, it's a security issue and probably related to your key. Then turn mac filtering off (leaving security on)
if you need help configuring security or MAC filtering, check your router documentation.
Thank You!
Solution #3
posted on Aug 11, 2008
Not Rated (0)
ghimireashok
Rating: 0%, 0 votes
Please Help Me: it just disconnect and shows not Limited connection, Not connected, when i troubleshoot it shows acquiring network address. so how can I solve the problems and how can I connect the wireless internet? Please help me. Plz how to configure the connection and 3com wireless setup.
pleae response me as soon as possible.
Thanks
ashok
Comment posted on Aug 11, 2008
Please Help Me: it just disconnect and shows Limited connection, Not connected, when i troubleshoot it shows acquiring network address. so how can I solve the problems and how can I connect the wireless internet? Please help me. Plz how to configure the connection and 3com wireless setup.
Thanks
ashok
Thank You!
Can you Help with these Routers problems?
Routers
when i hit pause/break button rommon1> doesn't come up,...
Routers
im sky broadband and want to connect a laptopa iv a edimax...
I have a Linksys WRT300N Router. I'm trying to connect my...
i have dsl through my cable and it say to go setting then...
I can help you if you havent
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
