Question about Microsoft Xbox 360 Console
Xbox 360 usb port
Is there a restriction or limit to the size of drive that can be used on the usb port. Flash drives seem to work, externals don't.
  • Wes Sydenstricker
    Wes Sydenstricker May 11, 2010
    There is a way you can make an external work no matter how many GB there are or you can upgrade your Xbox hard drive by cracking the case open and swapping it with a larger drive!! I have a 360 with a standard looking hard drive, but it's a 160GB hard drive inside!!
  • 344 Answers
Here is the link for the External USB hard drive Mod. You can add as much memory as you want. But you can't use it for Xbox live content. Check it out. I hope this answers your question.
http://www.llamma.com/xbox360/mods/USB%20Hard%20Drive%20Mod.htm
(I in no way am affiliated with llama.com, but they are very useful!)
Posted on Sep 04, 2008
Ive never had a problem with my 160 GB portable hard drive
Posted on Jan 28, 2008
    Scholar:
  • 85 Answers
4GB is the limit on the usb devices.
Posted on Jan 04, 2008
6ya staff
SOURCE:
Wont read a flash drive
Make sure the flash drive will work on a normal computer. If it does try a different port on the xbox. If it works on the computer and not the xbox you might have to format the flash drive to work with the xbox Go here USB flash drive support for Xbox 360 or How to Configure any USB Flash Drive as Storage on Xbox 360
Apr 03, 2014 | Microsoft Xbox 360 Console
Won't read the flash drive
Make sure the flash drive will work on a normal computer. If it does try a different port on the xbox. If it works on the computer and not the xbox you might have to format the flash drive to work with the xbox Go here USB flash drive support for Xbox 360 or USB flash drive support for Xbox 360
Xbox 360 error code:-3151-351f-1600-2203-c000-0001 when update. if i factory reset will i lose my firmware
This is what XBox sent me as an answer:
The console is looking for a previous version of the system update. Follow these steps:
  1. Find a USB flash drive with at least 90 MB of free space.
  2. Plug the USB flash drive into a USB port on your computer.
    Note The USB flash drive must use the FAT32 file system (Microsoft Windows).
Click on the followng site to download the update. GOOD LUCK
  1. Download the system update for error code xxxx-3151-xxxx-xxxx-xxxx-xxxx.
  2. Click Save to save the console update .zip file on your computer.
  3. Unzip the file. If you are using Windows XP, Windows Vista, or Windows 7, double-click the .zip file to unzip it.
  4. Copy the contents of the .zip file to the root directory of your USB flash drive.
  5. Unplug the USB flash drive from your computer.
  6. If there is a disc in the console, remove it.
  7. Turn off the console.
  8. Remove all console storage devices, including any USB flash drives, external hard drives, or the internal hard drive on the Xbox 360 S console. Learn how to remove the hard drive.
  9. Plug the USB flash drive with the update into a USB port on console.
  10. Turn on the console. When the console starts, the software update should automatically start.
Sep 18, 2011 | Computers & Internet
My xbox shows this code 3080-3151-b200-0700-c000-0059 and SYSTEM UPDATE STOPPED
Get a USB ready and Download this file
http://download.microsoft.com/download/4/b/5/4b502530-bc35-4477-b25a-aefdcfb7f504/systemupdate_12625_usb.zip
Once finished
Thanks
www.1RepairStop.com
Sep 10, 2011 | Microsoft Xbox 360 Console
My buffalo combo 4 2 TB wont show up on my xbox 360. I already have it formated FAT32
The Xbox 360 can only recognize drives up to 16GB as noted on their website, I myself have tried a 32GB flash drive to test the limitations and it was not recognized. At this time it seems as though microsoft is limiting their external storage to 16GB.
http://support.xbox.com/en-us/Pages/xbox-360/how-to/usb-flash-drive.aspx
Apr 02, 2011 | Buffalo Technology Buffalo DriveStation...
How can I flash my xbox 360? it wont recognize the new dvd rom drive.
Disconnect all cables from the Xbox 360 and remove the faceplate from the front of the console. Lift the plastic tabs on the outer shell and remove the plastic casing from the machine. Unscrew the Torx size 7 screws and lift open the metal cover. Unplug both the power and SATA cables from the rear of the DVD drive and lift it out of the console. Replace it with the new DVD drive, and connect the power cable to the unit. Connect your SATA cable to the DVD drive and a free SATA port on your computer.Turn on your computer and open a web browser. Download JungleFlasher and run the program. As of September 2010, JungleFlasher is the most stable and up-to-date flashing program for Xbox 360, and it is also the only program capable of flashing Xbox 360 drives from within Windows (earlier programs used MS-DOS). Click "Flash .BIN to DVD" in the program's main menu and select your Xbox 360's DVD drive. The program will flash the new DVD drive for use with your Xbox 360 console.Turn off the computer once the flashing process is complete and disconnect your SATA cable from the DVD drive and your PC. Reconnect the Xbox 360 SATA cable to the new DVD drive, then close the metal cover on the console. Rescrew the Torx size 7 screws and replace the outer plastic shell on the Xbox 360. Return the faceplate to its original position then reconnect all external cables and accessories to the console. Power on the Xbox 360 and the replacement DVD drive will function normally.
Feb 27, 2011 | Video Game Consoles & Games
My toshiba external hard drive wont work in 360, the portable device option is not highlighted once it is connected, the external is getting powered from the xbox though.
When you first put in your External hard drive to your computer, did it ask you if you wanted to use as a sort of passport or did it not give you any options at all like Usb flash drive. you should not have any special program on for the External hard drive. It should just be set up to store data and nothing else. I had a similar dilemma with a WD passport. When i put it on my 360 it did not work. then i just made the drive like a plain storage device and the xbox could read and play my files.
Dec 29, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
How to connect an extenal hard drive to my Xbox?
Get an external hard drive with a USB 2.0 connection. You need this connection to connect the drive to the console. Most recently manufactured hard drives
should have this type of USB adapter included. Format the hard drive to read FAT32 files. Using a Windows PC, create an FAT32 partition on the drive and format the volume. You'll need a program like
Partition Magic to do this. Load all the content you want from your PC onto the external drive. This should consist of photo files, MP3s and any other files that can be read on the Xbox
hard drive. Remove the external hard drive from your PC. Plug it into your Xbox 360 console through the USB port. go to the Media menu on your Xbox screen. Select "Portable Device" from the menu. All the readable files saved on the external drive should be available to
read on your Xbox 360 I am also adding a video//check it out if doubt persists.. vote for me...
  1. .utube.png You-Tube video "W-HVy5lMgtE" placeholder (do not delete) utube.png
Dec 25, 2010 | Microsoft Xbox 360 Console
How can I update my xbox 360 system
To update on Xbox LIVE:
  1. Connect your Xbox 360 console to the internet. If your console is not connected already, see Connect to Xbox LIVE.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
  6. Select Yes if you are prompted to update console software.
Copy the Update to a USB Flash Drive If you don't have an Xbox LIVE account or have a slow Internet connection, using a USB flash drive is a good option.
Note: The USB flash drive must use the FAT32 file system.
Update using a USB flash drive:
  1. Connect your USB flash drive to a USB port on your computer.
  2. Click here to begin downloading the update folder. Save it as "$SystemUpdate9199.zip" anywhere on your computer.
  3. Unzip the File.
  4. Copy the contents from the unzipped folder onto the root of your flash drive.
  5. Safely remove the flash drive from your computer and plug it into a USB port on your Xbox 360 console. If your console is on, turn it off, then back on. The update program will start automatically.
  6. Select Yes when you are prompted to update the console software.
Dec 15, 2010 | Microsoft Xbox 360 Console
How can I get this device to read on an xbox 360?
Step 1: Connect your hard drive to your PC.
Step 2: Create a FAT32 partition on your hard drive. If you’re using less than 32 GB, you can use Windows via “Control panel > Administrative tools > Computer Management”. If you’re using more than 32 GB, you’ll have to use an external program, e.g. Partition Magic.
Step 3: Load all the content you want from your PC onto the external drive. This should consist of files that can be read on the Xbox hard drive.
Step 4: Remove the external hard drive from your PC. Plug it into your Xbox 360 console through the USB port.
Step 5: Go to the Media menu on your Xbox screen. Select "Portable Device" from the menu. All the readable files saved on the external drive should be available to read on your Xbox 360.
N.B. Xbox's connection with an external drive is read-only. You can only read files that are already on the drive after connecting. You can't save game files or anything else on the Xbox main drive onto the external hard drive. Also, USB storage devices cannot be used for Xbox live marketplace content.
Apr 12, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Microsoft Xbox 360 Console Logo
2,235 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
