Question about SanDisk Sansa e260 MP3 Player
Sansa MP3 Model e260
When I insert my 1GB micro card the player doesn't recognize it.....
If you are still having the problem try this.
Take an ordinary pencil eraser. LIGHTLY go over the contacts of the micro disk, try to make sure to use a motion that goes from center of chip to outer edge. In this way you will avoid static electricity. The contacts should be a shiny gold.
If the contacts on the Sansa are visible, try the same for those contacts. If they are not visible, try to use a q-tip dipped in ordinary rubbing alcohol.
Try now with the contacts clean and dry.
p.s. It is usually the simplest things that go wrong, and that we overlook.
MacFalic
Posted on Jan 05, 2008
The Sansa E260 does not see the inserted SD card
Reboot the system and try again. You have to make sure it's shut down when you're inserting the card. If it still doesn't work make sure it has updated firmware. Sometimes that can cause some issue as well.
Feb 03, 2015 | SanDisk Sansa e260 MP3 Player
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
Micro sd memory card not recognized
Make sure your usb mode is msc plugin your sansa and go to my computer click on Sansa folder and you should see your removable disk this is your expansion card
Apr 17, 2009 | SanDisk Sansa e260 MP3 Player
My mp3 player won't recognize the memory card.
First, make sure it's a microSD card; the e260 won't work with microSDHC cards.
Then use a card reader to copy music tracks to a "MUSIC" folder on the card. Install the card into the e260 and you will see the additional music.
Mar 08, 2009 | SanDisk Sansa e250 MP3 Player
I need to know the maximum GB external micro sd card I can put in a sansa E260 4 GB Mp3 player and a sansa express 1gb mp3 Player.
thank you for choosing Fixya.com
you can use 4GB it is the applicable memory on your mp3.
if you will try to use much higher than 4gb sometimes it is the reason why our player are hanging up.
please don't forget to rate our answers properly.
Mar 05, 2009 | SanDisk Sansa e260 MP3 Player
My sansa player does not recognize a micro sd when its inserted
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
Mp3 Player not reading SD 1GB Card
The Sansa is unfortunatley one huge mess up the programming has failed its working on a database with only 4 levels but for grphics and songs you need at least 7 lhopefully you can return it and get another if not you can try putting another type of chip hopefully that will work
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
Sansa mp3 player could not detect micro sd add on card
Anything over 4GB is a Micro SDHC card, not a Micro SD card. It is a completely different type of card format on the inside, and despite the compatible size and shape, it will not work on devices labeled only as Micro SD card compatible. The Sansa e200 and up (e250, e260, ect.) are NOT COMPATIBLE WITH MICRO SDHC CARDS (Micro SD cards that exceed 2GB in capacity).
Dec 16, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
