Question about Navman iCN 520 GPS Receiver
Can NavMan 520 charge via USB?
I am currently wating for a new cable to charge my navman 520 which i have bought off ebay, but in the meantime is there any other way to charge? i have a usb cable and a usb charger but nothing happens, it will not even turn on anymore!
  • craphex Jan 30, 2008
    Bought a charger off ebay, but it works!
    Only problem now is, i have maps, but i am getting no signal at all!
    Just that it cannot connect!
    I have tried in car, standing outside, while plugged in, full battery etc :(
    Any ideas?
I received a navman as a present but it only has a card connection to charge but how can charge for 8 hours for the first use. happy to hear any suggestions!!!!!
Posted on Sep 01, 2011
That is probably due to the battery being totaly dead,
try using a mobile phone charger (nokia),
usb is for data transfers.
Posted on Jan 30, 2008
I need to download New Zealand maps (North Island) to my Navman MY80T
install the nav desk software to you p.c and connect the navman to the pc via the usb cable.
You will be prompted that a map upgrade is available through the NavDesk software. Once the unit has synchronized with the NavDesk software you will be informed that a later map is available. Once you select the map data, it will begin to download to your computer.
May 13, 2017 | Navman GPS
My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
1. Connect Navman GPS to PC via mini-USB cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the Navman Unit
5. Open the 'Navman' folder
6. Open the 'Database' folder
7. Delete the following file only - 'dababase.db'
8. Close the folders
9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
Nov 04, 2010 | GPS
Navman f20 will charge fron usb port on computer but not with in car charger
If it's not the original Navman usb loader then there's a easy solution to this : With a sharp knife carefully open the usb cable : you'll see four tiny cable's with different colours . You;ll have to cut two of those four cables ; Leave the black and red cable intact.
Use some tape to fix the cut in the usb cable. Now you can use your car charger and your navman won't go into usb mode.
Dec 08, 2009 | Navman F20 GPS Receiver
I have a navman s90i . When i plug the car charger in the screen shows a compuyer runing into a navman via a cable then shuts down then try's to start but goes to the above screen
No solution but exactly the same model and exactly the same problem. When I put the car charger on the unit, it goes off and then comes back on and ust shows a computer as though the only option it can handle via usb is a computer connection. Interestingly, it still charges, but just becomes useless as a satnav as there are no maps, directions or any scree functionality at all.
Nov 22, 2008 | Navman GPS
Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
May 11, 2008 | Navman iCN 520 GPS Receiver
Navman icn520
check the battery switch on the back. you will need a pen. Mine does the same thing. I believe this switch has to be set to ON for it to work. At least mine wont turn on unless the switch is turned on.
Apr 10, 2008 | Navman iCN 520 GPS Receiver
Navman icn 520 with smartST 2005
You can unlock the iCN520 and install other GPS software on it. The iCN520 can run virtually all the major GPS software available today; from Tomtom to Miomap and beyond.
Instructions on how to unlock the iCN520 can be found at:
Mar 22, 2008 | Navman iCN 520 GPS Receiver
Navman iCN 520
The CD is not available for download from Navman it seems, but you can get it at Just search for 'navman icn' and you'll find what you need, I just did. Better learn how to download torrents though! :)
Feb 14, 2008 | Navman iCN 520 GPS Receiver
Navman f10
i was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
Dec 28, 2007 | Navman Tracker 5500i GPS Receiver
Navman iCN 520 GPS Receiver Logo
1,441 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
