Remotes won't work
I have an Airwell ducted air conditioning system in my house and until recently the 2 remotes that operate it worked fine. I have changed the batteries and they still didn't work so I tested the remotes in my friend's house as she has the same air conditioner. There my remotes work. Can you tell me what is going on? I have a few items that use remotes but have turned off the ones I bought in the time the a/c remotes stopped working and it doesn't make any difference.
  • lozzab Jan 05, 2008
    I have a receiver board upstairs and one downstairs and neither remote works on either of the receiver boards. I had already tried the reset buttons and also tried cutting the power to air conditioner. They still don't work. I think it would be too much of a coincidence for both receiver boards to become defective at exactly the same time. And as I said the remotes work in my friend's house. Do you have any other ideas for me? Thank you.
  • 236 Answers
There is a reset button in your remote try to reset it then try the remote to your unit. If it wont work then the receiver board is defective.
Posted on Jan 04, 2008
  • Felizardo Erilla
    Felizardo Erilla Jan 05, 2008
    Some remote control have have also the address switch which the address of both unit and remote control should be the same. Some address can be adjusted by configuring the remote control, and some address can be adjusted by transferring the switch ( A and B). Try to read your service manual.
    Try to look at the back of your remote control at the battery compartment check if there is a switch labeled A and B, adjust it and reset your remote and try.
    HERE IS A SAMPLE OF ADDRESS CONFIG.
2 Suggested Answers
NiHaoAirwell
  • 7 Answers
SOURCE: We have just purchased a universal remote for our
Airwell remote controls (RC) are not coded (so not listed) for universal use.
The only way of using a universal remote control is to learn the new RC by sending the commands piece by piece with a original Airwell RC.
Posted on Aug 10, 2010
Needing information on removing a heater core from a 2012 Chrysler 200
how to? that it the full steps, out and in,,>????
there is lots of information on this....
not in warranty? huh?
and how could IT be bad so soon?? no way/ ,huh?
why not post the symptoms and not guess. the below HORROR
posted to show 2 days lost work (life)
buy the FSM and read the HVAC chapter. every word
or alldata.com , same deal. look, read and decide,
oops I cant to this.....?
parcial excerpts. to prove case.
quote:
The HVAC housing assembly must be removed from vehicle for service of the heater core.
housing out: 101:
Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in an accidental airbag deployment and possible serious or fatal injury.
WARNING
Refer to the applicable Warnings and Cautions for this system before performing the following operation and . Failure to follow these instructions may result in possible serious or fatal injury.
NOTE
The HVAC housing must be removed from the vehicle and disassembled for service of the heater core, A/C evaporator, air intake housing and the mode-air and blend-air doors.
NOTE
LHD model shown in illustrations. RHD model similar.
Heat Shield - Unified Line 08 JC
Disconnect and isolate the negative battery cable.
Recover the refrigerant from the refrigerant system (Refer to Heating and Air Conditioning/Plumbing - Standard Procedure).
Partially drain the engine cooling system (Refer to Cooling - Standard Procedure).
Remove the top nut (2) that secures the heat shield (3) to the stud (1) located on the dash panel.
NOTE
Two slots are provided at the bottom of the heat shield to aid in heat shield removal. Complete removal of the two bottom heat shield retaining nuts is not required.
Reach behind the engine and remove the two bottom nuts the that secure the heat shield to the studs located on the dash panel and remove the heat shield. Rotate and tilt the heat shield as required.
(capture the FREON as required by USA LAWS, Illegal for DIY person to do. so...)
Unified Liquid and Suction Line to Evaporator 08 JS
Remove the bolt (1) that secures the A/C liquid and suction line assembly (2) to the A/C evaporator (3).
Disconnect the A/C liquid and suction line assembly from the A/C evaporator and remove and discard the dual-plane seals.
Install plugs in, or tape over the opened refrigerant line fittings and the evaporator ports.
Disconnect the heater hoses (4) from the heater core tubes. Install plugs in, or tape over the opened heater core tubes to prevent coolant spillage during housing removal.
HVAC Housing to Dash Panel Nut
NOTE
Make sure to remove the five bolts that secure the HVAC housing to the instrument panel support prior to removing the instrument panel from the vehicle.
Remove the instrument panel (Refer to Body/Instrument Panel/PANEL, Instrument - Removal).
Remove the rear floor ducts (Refer to Heating and Air Conditioning/Distribution/DUCT, Floor Distribution - Removal).
Remove the condensation drain tube (Refer to Heating and Air Conditioning/Plumbing/TUBE, Condensation Drain - Removal).
Remove the nut (1) that secures the passenger side of the HVAC housing (2) to the dash panel (3).
NOTE
Use care to ensure that the interior is covered in case of loss of residual fluids from the heater and evaporator cores.
Pull the HVAC housing rearward and remove the HVAC housing assembly from the passenger compartment.
at the least, and for sure , things will break, as you work.
get lost, or not figure out how to put it ALL BACK
Remove the HVAC housing assembly and place it on a workbench (Refer to Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal).
Remove the left side front floor duct (Refer to Heating and Air Conditioning/Distribution/DUCT, Floor Distribution - Removal).
NOTE
If the foam seal for the flange is deformed or damaged, it must be replaced.
Remove the foam seal (1) from the flange (2) located on the front of the HVAC housing (7).
Remove the screw (8) that secures the flange to the front of the HVAC housing and remove the flange.
Remove the screws (3) that secure the heater core tube retaining brackets (6) to the side of the air distribution housing (4).
On RHD models, remove the air distribution housing from the HVAC housing (Refer to Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal)
Carefully pull the heater core (5) out of the driver side of the air distribution housing.
end excerpt.
May 13, 2014 | Cars & Trucks
Commercial airconditioning help needed
make a communication to the manager of airwell and state that the unit is malfunctioning and you want technical assistance to get it to operate as designed
Nov 15, 2017 | Heating & Cooling
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
I got an Airwell ducted air conditioner unit with 4 outlet model: GC24RCC-S and Remove controller 4 and PCB unit is Storm 2. When turned on, the green operation led of the display controller unit is...
Check the unit that's located outside .You need to open it to get to the control board ,there you will see a couple of buss fuses. Check to see if fuses are fine. Do this with the power OFF on disconnect
May 19, 2017 | Heating & Cooling
We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
-Is this a Residential AC Unit?
-If it is a residential AC unit, where is the thermostat located for this unit?
-Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
Hope this helped... :D
Jun 27, 2010 | Heating & Cooling
Looking to replace heater core
Cherokee, Grand Cherokee, 1999-2005
Removal & Installation
  1. Disconnect and remove the negative battery.
    CAUTION After disconnecting the negative battery cable, wait 2 minutes for the driver-s/passenger-s air bag system capacitor to discharge before attempting to do any work around the steering column or instrument.
  2. Drain the cooling system into a clean container for reuse.
  3. Remove the instrument panel by performing the following procedure:
    1. Turn the steering wheel in the straight-ahead position.
    2. Remove the knee blocker from the instrument panel.
    3. Remove the steering column; do not remove the air bag module, the steering wheel or switches from the steering column.
    4. From under the driver-s side of the instrument panel, disconnect the following items:
      Instrument panel wiring harness connector from the 100-way wiring harness connector at the left side of the inner panel. Side window demister hose at the heater/air conditioning housing demister/defroster duct on the driver-s side.
    5. Remove the glove box.
    6. Reaching through the glove box opening, disconnect the following items:
      Two halves of the heater/air conditioning system vacuum harness connector. Instrument panel wiring harness connector from the heater/air conditioning system wiring harness connector. Instrument panel wiring harness connector from the passenger-s side air bag module wiring harness connector. Side window demister hose at the heater/air conditioning housing demister/defroster duct (passenger-s side). Two halves of the radio antenna coaxial cable connector. Two instrument panel wiring harness connectors from the passenger air bag ON/OFF switch wiring harness connector. Passenger-s side air bag ON/OFF switch wiring harness from the retainer clip on the plenum bracket that supports the heater/air conditioning housing just inboard of the fuse block module. Two lower passenger-s side air bag module bracket-to-dash panel nuts.
    7. Remove the upper cover from the instrument panel.
    8. Remove the 3 instrument panel-to-door hinge pillar screws.
    9. Remove the 4 upper instrument panel-to-dash nuts.
    10. Using an assistant, remove the instrument panel from the vehicle.
  4. If equipped with air conditioning, discharge and recover the air conditioning system refrigerant.
  5. Disconnect the refrigerant lines from the evaporator. Plug the refrigerant openings to prevent evaporation.
  6. Disconnect the heater hoses from the heater core tubes.
  7. Disconnect the heater/air conditioning system vacuum supply line connector from the T-fitting near the heater core tubes.
  8. In the engine compartment, remove the 5 heater/air conditioning housing-to-chassis nuts. If necessary, loosen the battery hold-downs and reposition the battery for access.
  9. Remove the cowl plenum drain tube from the heater/air conditioning housing stud; it-s located behind the cylinder head on the cowl.
  10. From the bottom of the heater/air conditioning housing, remove the floor duct.
  11. On the passenger side, remove the heater/air conditioning housing-to-plenum bracket screw.
  12. Pull the heater/air conditioning housing down far enough to clear the defrost/demist and fresh air ducts, then, rearward far enough to clear the mounting studs and the evaporator drain tube to clear the dash panel holes.
  13. Remove the heater/air conditioning housing assembly from the vehicle.
  14. Remove the heater/air conditioning housing upper case.
  15. Lift the heater core from the lower half of the heater/air conditioning housing.
To install:
  1. Assemble the heater core into the lower half of the heater/air conditioning housing.
  2. Install the heater/air conditioning housing upper case.
  3. Install the heater/air conditioning housing assembly to the vehicle.
  4. On the passenger-s side, install the heater/air conditioning housing-to-plenum bracket screw.
  5. At the bottom of the heater/air conditioning housing, install the floor duct.
  6. Install the cowl plenum drain tube to the heater/air conditioning housing stud; it-s located behind the cylinder head on the cowl.
  7. In the engine compartment, install the 5 heater/air conditioning housing-to-chassis nuts.
  8. Connect the heater/air conditioning system vacuum supply line connector to the T-fitting near the heater core tubes.
  9. Connect the heater hoses to the heater core tubes.
  10. Connect the refrigerant lines to the evaporator.
  11. If equipped with air conditioning, evacuate and charge the air conditioning system refrigerant.
  12. Install the instrument panel by performing the following procedure:
    1. Using an assistant, install the instrument panel to the vehicle.
    2. Install the 4 upper instrument panel-to-dash nuts.
    3. Install the 3 instrument panel-to-door hinge pillar screws.
    4. Install the upper cover to the instrument panel.
    5. Reaching through the glove box opening, connect the following items.
      Two lower passenger-s side air bag module bracket-to-dash panel nuts. Passenger-s side air bag ON/OFF switch wiring harness to the retainer clip on the plenum bracket that supports the heater/air conditioning housing just inboard of the fuse block module. Two instrument panel wiring harness connectors to the passenger air bag ON/OFF switch wiring harness connector. Two halves of the radio antenna coaxial cable connector. Side window demister hose at the heater/air conditioning housing demister/defroster duct (passenger-s side). Instrument panel wiring harness connector to the passenger-s side air bag module wiring harness connector. Instrument panel wiring harness connector to the heater/air conditioning system wiring harness connector. Two halves of the heater/air conditioning system vacuum harness connector.
    6. Install the glove box.
    7. Under the driver-s side of the instrument panel, connect the following items:
      Side window demister hose at the heater/air conditioning housing demister/defroster duct on the driver-s side. Instrument panel wiring harness connector to the 100-way wiring harness connector at the left side of the inner panel.
    8. Install the steering column.
    9. Install the knee blocker to the instrument panel.
  13. Connect and remove the negative battery.
  14. Refill the cooling system.
  15. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Hope helps (remember rated this).
Jun 25, 2010 | 2001 Jeep Grand Cherokee
Banging noise when motor turns off
Have you replaced your air filter recently? Often this is a symptom of a restricted return. The blower almost causes a vacuum in the duct work, and when the system shuts down the duct "pop" back out, causing this banging noise. Hope this helps
Feb 05, 2010 | Honeywell Electronic Programmable...
Hearter core removal
  1. Disconnect the negative (-) battery cable.
  2. Drain the engine coolant into a suitable container.
CAUTION When draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Disconnect the heater hoses. Be careful not to damage the core by pulling on the hose to remove. Cut the hoses if they will not come off easily.
  2. Remove the instrument panel.
  3. Disconnect the resistor assembly.
  4. If possible, disconnect and move the duct (non air conditioning) or the evaporator housing (air conditioning) to the right to gain clearance for the heater unit. If equipped with air conditioning, do not disconnect air conditioning system until absolutely necessary. Refer to for discharging, evacuating and recharging the system.
  5. Remove the instrument panel stay and heater unit.
  6. Disassemble the heater unit by removing the duct, mode control case, core assembly and heater core.
To install:
  1. Assemble the heater unit by installing the duct, mode control case, core assembly and heater core.
  2. Install the heater unit and instrument panel stay.
  3. Connect the duct (non air conditioning) or the evaporator housing (air conditioning) to the heater unit. Evacuate and recharge the air conditioning system if the system was discharged to remove the evaporator assembly.
  4. Connect the resistor assembly.
  5. Install the instrument panel as outlined in this section.
  6. Connect the heater hoses. Be careful not to damage the core by pulling on the hose.
  7. Refill the engine coolant into a suitable container.
  8. Connect the negative (-) battery cable and check for leaks.
Jan 20, 2010 | 1996 Isuzu Trooper
How do you change the heater core in a 2002 Dodge Intrepid?
  1. Disconnect the negative battery cable from the remote battery post located near the right strut tower.
    Remove the instrument panel by removing or disconnecting the following:
  2. NOTE On the LHS or 300M, remove the center bezel prior to the shifter bezel
    Shifter knob Allen screw Both instrument panel end covers Using a trim stick tool, gently pry upward on the shifter bezel; then, disconnect both wiring connectors and a light bulb socket connector; then, remove the socket.
  3. Remove the 2 lower instrument panel cover screws (outside end) and disconnect the deck lid release switch wiring connector. Pull the lower instrument panel cover rearward releasing the clips. Remove the cable-to-brake release handle. Pull the cover rearward and remove it.
  4. If equipped for 6 passengers, remove the lower floor bin.
  5. If equipped for 5 passengers, remove or disconnect the following items:
    Center bezel using the trim stick Heater/air conditioning housing assembly control switch and the traction control switch wiring harnesses Bezel from the vehicle Two left side console side cover screws, pull the cover outward and remove from the vehicle Lower glove box door; the 2 screws are located at the right console side cover, pull outward and remove it 2 bracket screws and the 2 inside the console bin; then, remove the console 2 center lower instrument panel nuts 4 steel reinforcement-to-lower instrument panel cover bottom bolts 16-way DLC from the reinforcement left floor duct/silencer pad screw and the pad Steering column shrouds Shift interlock cable at the ignition switch Column wiring The under column duct section Left panel air conditioning outlet duct The 4 brake pedal support bracket-to-column mounting bolts Lower the steering column Heater/air conditioning housing and the Air bag Control Module (ACM) harness connectors then, the 2 ground eyelets from the floor tunnel near the bulkhead Using a trim stick, carefully, pry out on the left and right A-pillar trim moldings and slide them rearward to remove them.
  6. Using a trim stick, carefully pry upward on the instrument panel top cover, and remove it.
  7. From both sides, remove the scuff plate screw. Using a trim stick, carefully, pry out the scuff plates and remove them.
  8. Remove or disconnect the following:
    3 right side cowl panel screws and the panel 3 left side cowl panel screws and the panel Remove the right side under dash silencer and pad 2 right side radio antenna and amplifier harness connectors Left side junction block and Body Control Module (BCM) harness connectors 8 instrument panel-to-chassis screws Pull the instrument panel rearward Instrument panel from the vehicle with the help of an assistant ischarge and recover the air conditioning system refrigerant.
  9. Drain the cooling system into a clean container for reuse.
  10. Place shop cloths in the interior to catch any excess coolant.
  11. Remove or disconnect the following:
    WARNING The air conditioning lubricant used in this system absorbs moisture readily. Do not leave any portion of the system open for any long period of time.
    Air cleaner hose and the air distribution duct Heater hoses-to-dash panel spring type fasteners and the heater hoses from the heater core. Plug the openings to prevent coolant spillage. Refrigerant lines-to-expansion valve nut and separate the refrigerant lines from the expansion valve. Plug the openings to prevent contamination. 3 heater/air conditioning housing assembly-to-chassis nuts from the engine compartment 2 defroster duct screws and the duct Heater/air conditioning housing assembly-to-dash panel nuts and screws 4 rear seat heat duct nuts and the duct Rear seat heat duct elbow push-pin fastener Electrical connector from the heater/air conditioning housing assembly Pull the heater/air conditioning housing assembly rearward and remove it from the vehicle 2 heater core-to-heater/air conditioning housing assembly screws Heater core from the heater/air conditioning housing assembly
contact me and i can tell you how to put it back together
Jun 28, 2009 | 2002 Dodge Intrepid
Heating & Cooling Logo
1,394 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
