Interior Light Is Out -- Cannot figure out how to find it, let alone change it. An electrician was at our home today and couldn't find it. We removed the circular disk at the inside top of the microwave but all that's there is a spinning device, no bulb. Any ideas? Allan
I replaced the two bulbs underneath the microwave 2 months ago. The bulbs blew out again. Also the light only turned on once inside the microwave. How do you get to the light that suppose to light up when your warming your food? Does anyone have these problems?
Posted by Guest on May 24, 2008
where is lightbulb for ge spacemaker microwave oven
No power to GE Profile XL1800 Microwave Oven. Is their a reset button anywhere? Breaker is O.K. & I unpluged the Oven and pluged it back in. No Power !!!!!!
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on ge profile spacemaker XL 1800 undercabnet microwave:
Best Solution
posted on May 08, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
Home depot sells the lights as I believe reffigeratro bulds. bring the old ones with you to match them up. i got a price from an appliance parts place of $40. The depot was like $6.
Best Solution
posted on Aug 08, 2008
Guest
After searching GE's site high and low I finally found some pitifully basic instructions which I've elaborated on here.
Bulb required: Manufactured by Aglaia for GE, 130V 35W Halogen bulb GE #WB08X10051 or equivalent.
There is a grille above the door and clock/cooking controls that extends the width of the unit. You need to remove this to
get to the light receptacle. With the power to the unit off (unplug if you have access to it), get on a chair with a Phillips
head screwdriver. Look down from the top and you will see two screws about 6" in from the ends. If you don't see the
screws, open the cabinet doors above the unit (mine were blocking the screw heads). Remove the screws and set aside.
Pull girlle towards you at the top being careful not to break the tabs at the position where the screws you just removed are
located. After the tabs are out the grille should lift up (there are three hook-tabs along the bottom). Set it aside. Over
toward the right you will see a smaller vertical grille. Just to the left of this there is a void with a Phillips head screw facing
you. Remove the screw from the receptacle tab. Lift up the receptacle tab on the right. When the receptacle is clear on
the right, move the receptacle to the right to release it from the tabs on the left. Lift the receptacle up until it clears the
housing it just came from. Pull it gently toward you, rotate it bottom-toward you, and you will see the bulb to be replaced.
My bulb was lightly held in using white silicone and removed easily by pulling it in the direction it was pointing. A word of
caution about Halogen bulbs: When handling new bulbs be careful not to get any grease on them and handle them with
clean cotton gloves or a clean t-shirt. Grease and oils from even clean hands will cause the bulb to burn out quickly.
Replace the receptacle being careful to make sure the electrical wires are not pinched by the receptacle housing. Replace
the screw; replace the grille; return power to the unit. You're done!
To find the bulb I Googled "General Electric WB08X10051" and "Lamp Halogen WB08X10051" and found options ranging
in price from $8.10 to $10.71 ($13.50 with GE).
Our microwave was working and stopped - basically it locked it self out. Now if you try to push any buttons, it says "Control Locked". Do you know anything about his?
Thanks
