Question about Computer Monitors
Gericom tft screen
Gericom 19" tft screen mains power board not working
4 Suggested Answers
  • 732 Answers
SOURCE: I turn on my Rosewill 19
14brad, It sure sounds like the "switch-mode-power-supply" has detected a fault with some other circuit or with itself and is going in and out of SHUTDOWN mode to try and save itself from having a nonrecovrable catastrophic failure. A tech will need to evaluate it, or he will buy it from you for $5 US. If he is lucky he will put less than $6 in parts into it and resell it for $40-$60. Go visit YOUTUBE and search and view video clips of LCD monitor disassembly and LCD monitor repair. also try or and for more info. Then you will be able to make a decision on what course of action you will want to take be it repair or trade-in for new monitor. If this was good info for you, please rate this response on fixya. 12fixlouie
Posted on Oct 28, 2009
  • 11361 Answers
SOURCE: daewoo w9zq 19"tft power light flashes but no screen :s
Open it up and check for bad caps in the power supply first, post back what you see so we can guide you further, see example of failed monitors due to bad caps:
Posted on Feb 12, 2010
Testimonial: "Worked a treat, you are the man budmrtn ;) Thank you very much."
  • 1684 Answers
SOURCE: Hi, I need schematic diagram for IP-48135 T board....
The schematic diagram is going to be very hard to get. We do repairs on this model. What information do you need? The most common problem is the capacitors on the power board. You can find this repair guide at: If you need other information then let us know at: and we will get glad to assist you in the repair.
Corporate Computer
Posted on Jul 12, 2010
  • 1288 Answers
SOURCE: My 19" TFT LCD monitor
Power capacitor problem, needs taking to a qualified TV repairshop to have the capacitor replaced / checked
Posted on Dec 28, 2010
0 characters
1 Points
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Main board too should be checked. Contact any service technician.
Oct 03, 2014 | Computer Monitors
Samsung TFT 19 LCD no flashing red LED continues on replaced all caps
did you check the output dc voltage of the power supply if present. if ok, then doesn't turn on the problem is with in the main board.
Oct 10, 2012 | Computer Monitors
I have a FPD1975W tft LCD monitor and the screen will blink on but then shut off. the power button still shows on though. i've checked all connections and did a cleaning as well but cant get the monitor...
The description points to the inverter board which energizes the back lights behind the screen, and is on the verge of failure. The cause is usually bad capacitors, the board will need to be replaced or a attempt to repair the existing one. If a professional gets involved the parts and labor can run high.
Feb 09, 2011 | Gateway 19" Widescreen Flat Panel TFT LCD...
I have a Samsung SMT-190 19" FLAT PANEL monitor and the picture won't show but a few minutes and then a sound comes on and the power light is blinking and the picture goes out and leaves only the blank...
More then likey yuor Inverior Board is going bad if not that, Its the Power Board
First check Invertor This Happens a lot Its hard to find someone to fix it.
Well I had a hard time. I just waited and bought one for parts and fixed it Myself
Good luck
PS. You can still use it just get a different Monitor. The Video out on the Samsung to the
Video in on a different Monitor IT WILL WORK
Jul 13, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
Dell Monitor 1907FPt comes on for a short time and goes to a black screen. Power light is still on. How do I fix this?
Mar 01, 2009 | Dell E173FPb 17" TFT LCD Monitor
Emachine 19" Widescreen Flat-Panel TFT-LCD Monitor
Your power/inverter board is in need of an overhaul.
The capacitors are failing and possibly a transistor.
If the screen showed any redness or pink whebn it was working, Then there is a slight chance that one or more of the 4 lightbulbs in the screen was going bad and finally went.
If you take it apart and send me a picture, I may be able to tell by looking at it.
I repair these boards on ebay
Nov 05, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Gericom TFT Monitor
Is the brightness flickering or are the images moving about.
If the brighness, The bulbs are possibly beginning to go and after they warm up they stay put.
If it is the image, then the video board could be doing the same. A failing voltage regulator on the video card board will make a picture streak or wiggle.
There is also a chance due to age that the power board voltage is starting to get weak due to common failing capacitors.
Oct 12, 2008 | Computer Monitors
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Dell 1703 FPi 17" TFT LCD Flat Panel
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Sep 06, 2007 | Dell 1703FPt 17" TFT LCD Flat Panel...
Computer Monitors Logo
334 people viewed this question
Top Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Computer Monitor Expert? Answer questions, earn points and help others
