Hobart SR24-H Built-in Dishwasher
Machine isn't Sanitizing! HELP!!!!!!!!!
posted by picnicbasket on Jan 04, 2008
This machine is only 3 years old and it isn't pulling the bleach to sanitize the dishes....why is this? How can I fix this problem...someone please help me
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 05, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Usually after three years the pump tube in the pump breaks down from exposure to the chlorine. You need to replaced the pump tube. Also the end of the tube that delivers the clorine could be plugged as chlorine is famous for crystalizing and plugging the tubes. Also check to make sure that the pump is running.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Machine isn't Sanitizing! HELP!!!!!!!!!:
I don't want to Accept this solution
Solution #2
posted on May 09, 2008
Not Rated (0)
wildhorsees
Rating: 0%, 0 votes
it could be the soap dispensing were the hoses connect in the manifold there could be a build that formed and those not let the soap go true take the manifold out clear the hole and it should be ok
Thank You!
Can you Help with these Dishwashers problems?
Dishwashers
my display says ''water heater fault'' do I need to...
Dishwashers
I have Whirlpool dishwaher ADP 5550 and the problem is...
Dishwashers
Unit will not turn on. Washing light blinks continually...
when i put the handle down, the hot water didn't come out,...
my rack temp in the rinse is low ( about 153F)yet the...
Loading problems.
Repair Service
Find Dishwasher Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
