Just in case you don't have the manual I also included the steps to input the codes. Hope this helps
Follow these steps to program the remote control. NOTE: Even though the FUNCTION buttons are labeled for specific components, they can be programmed to operate any
type of equipment that is compatible with this remote control. For
example, the BD/DVD function can be programmed to operate a VCR, AV receiver, etc.
Turn on the component to be programmed.
On the remote control, press and hold the INPUT button.
While holding INPUT button, press the FUNCTION button for the desired component.
Release both buttons.
NOTE: The FUNCTION button will blink for approximately 30 seconds or until a code is entered.
Using the number pad, enter the component's manufacturer code.
NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
Press the ENT button.
NOTE: The FUNCTION will blink twice if the programming is successful, if not, it will blink five times.
Point the remote control at the component.
Press the component POWER button to verify operation.
NOTES:
If a new code number is entered, the code number previously entered will be erased.
When the batteries are replaced, the programmed codes
may be erased. It may be necessary to reprogram the remote after
replacing the batteries.
Some product functions may not be able to be controlled
by the remote control. Use the remote control provided with the
component.
In some rare cases, you may not be able to operate your
non-Sony equipment with the supplied remote control. This is because
your equipment may use a code that is not provided with this remote
control. In this case, use the remote control that was provided with
the equipment or purchase a universal remote control that has a
learning function.
If programming fails, it may be necessary to reset the
remote control. To reset the remote control, remove the batteries and
press each button on the remote control twice.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
