Question about RCA F36650 36" TV
No power now all it does is click
My T.V turned off by itself and would not turn back on for awhile. Now
when I plug it in all it does is make a high pitched clicking sound. In other
submissions it has been said that it could be the flyback trransformer. If it was this could I do this myself and if so where can I get one?
Thank you
  • trftabor Jan 04, 2008
    I have soldered a little. Is this something that I would be able find easily in the tv. If I were to bring this in to a shop how much do you think this would cost? I debating on if I should just get a new tv.
  • Anonymous Jan 23, 2008
    I have a 36" TV F36676ET. It was working fine, then next day when I tried to turn it on, I would just here some "clicking"noices like it was trying to turn on. Each time I pressed to On button, the TV would "click" 4 times and not turn on. My TV is 9 years old. Is it worth fixing?
  • 1,694 Answers
Flyback bad = part # 257805 or ASTI 2078......
Are you mechanically inclined and can you solder ?
Look it over first.....................T.
Posted on Jan 04, 2008
I had a bad storm and the TV turned off. When I went to turn back on, I couldn't turn the TV back on with my remote. So I turned on by hand it immediately would turn off by itself after 2 seconds every...
It appears that there may have been a power surge or something that damaged the electronics of your set and cause it to work the way it is now. You might want to try replacing the power supply since it is the first area that would have a surge go through it and sustain the damage.
Aug 24, 2017 | Televison & Video
My akai dlp tv turns itself off then it flashes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 17, 2010 | Akai LCT3201TD 32 in. LCD Television
I have a hitachi p50x01au plasma and I was just watching tv and it turned off by itself.I tried to turn it back on and all I get is a green blinking light.Do I need to call a technician?
you need to unplug power cord from back of tv and let it set for awhile then plug back into the back of the tv i also have a plasma and it sometimes does that also
Jan 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
The unit turns on by itself
keep pressing display demo button for will show no demo and you're done
Aug 03, 2009 | Panasonic SC-AK78 CD Shelf System
There is 2 reasons for this poor solder on power AC board and a capacitor going bad. cap when failing will puff up on top.
Nov 29, 2008 | Akai PT4799HD Rear Projection Television
Samsung Projection TV
try unplugging the 3 wire plugs for the convergence yokes and try powering up the set. if it comes on you will need convergence ICs if it doesnt you will need a deflection board. let me know what you discover as I can help you with either problem
Jun 19, 2008 | Samsung HCN4226W 42" Rear Projection...
Rca proscan PS35152 - power on ?
I have the same problem - I know it is the power supply and want to repair/replace it myself. Where can I buy the Power Supply or what goes bad on it ? Need part # and where to buy. Thanks!
Dec 02, 2007 | Televison & Video
TV Turns off on its own
Just keep smack'in it around, it works for me. It is the 'protection overload circuit' taking over and shutting the TV set off. This is because it detected a short or near-short circuit somewhere. Most common is high voltage, deflection amplifiers and main power supply. It's pretty much a common fix for an experienced tv repairman. It might set me back in the ballpark of $200 - $300.
Jul 03, 2007 | Sylvania SRT4127P TV
TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
Oct 24, 2006 | Mitsubishi WS-55613 55" Rear Projection...
RCA F36650 36" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
