Cobra 25 LTD 40-Channels Base CB Radio
Problem for Cobra 25 LTD 40-Channels Base CB Radio
How do i install a cb radio on a pick up truck
By tyrese05 on Nov 04, 2009
how do i install a cb radio on a pick up truck
Best Solution
posted on Nov 04, 2009
Very Helpful)
mchaos
Rank: Guru  Cobra Car Audio & Electronics  Expert
Rating: 90%, 86 votes
You will need a CB radio antenna, The CB radio and mounting hardware as well as the power wire.
Choose a place to mount the radio. Mount it. Run the power wires from the radio to the fuse box. Put red wire in with the fuse that is hooked to switched 12 volt. Ground the black wire to any metal of the vehicle.
Next find a place to mount the antenna. If you use a mag mount, the roof of the cab is a best bet. Run the wire into the vehicle, it can go through the door, just make sure its not going to get pinched.
Hook the coax from the antenna to the radio
Now you have to tune the antenna. this is important because if you don't you you will blow the transmit final transistor out in the radio.
This link will take you to an article that will explain how to tune your antenna.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Cobra 25 LTD 40-Channels Base
Questions and Unsolved Problems for Cobra 25 LTD 40-Channels Base
Do you recommend Cobra 25 LTD 40-Channels Base CB Radio?
Answer
Answer
Im using a Cobra 29 and when I key up, my wipers like to come on until I release the mic. Why is... (More)
Answer
Hello! I need the Volksline ETR manual. Where I can find it? Tanks.
Answer
trc474 realistic. low volume and mod light is staying on .tx scale goes up when mic is keyed. max rf... (More)
Answer
I suspect the speaker as well on my unit as I have it wide open and can barely hear anything. Rf... (More)
Answer
Have him also try a Pa test with the spkr plugged in the pa slot to see if the mod section is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CB Radio Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
