Question about Brother DCP-110C All-In-One InkJet Printer
Error 5A i had this printer for quite some time already and had its cartridges refilled. now i tried to test print it but it won't. i get this error 5A when in maintenance mode what does this mean. i also get a cranky noise inside the printer when start black is pressed or to print for that matter. then it says scanner cover is open, sometimes a paper jam that does not exist. please help me w/ this...
  • 832 Answers
The purge cam has stopped abnormally.
The unit might be defective or the encoder disc which is mounted on one of the three big gear wheels is stained
or broken.
I guess the purge cam shaft is broken (this is the noise you can hear)
Anyway you have to change the whole print unit.
The spare part costs are more then a new dcp 130c 0r 135c!
Even if you try to change the parts with another dcp 110c its not worth the costs and energy because of other probs that might happend...
Posted on Jan 04, 2008
2 Suggested Answers
bowdo
  • 78 Answers
SOURCE: i have an error 5A in my dcp-110c
Purge unit error. Check for a piece of paper in the purge unit - right hand side of printer where the carriage sits. Trick the machine by powering off while carriage is moving and check for paper under the cover. If no paper there is a problem you can not correct and you need to get it serviced.
Posted on Jan 21, 2008
MFC-J435w when trying to print I get error 5A Help?????
buy a new one. there is no repair for print heads. and don't use refill inks.
not good for print heads
Aug 01, 2017 | Brother MFC-465CN InkJet Printer
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
How to error e5 how to go to service mode
Hum....e5 error.
The truth is...there is no solution for e5 error.
U may see some solutions through web, however, non of them works..
The only way you can get out of e5 error, replace with new cartridge..
or...
prevent it...before you face it!!
How?
Whenever you take out the cartridge from printer, make sure unplug the power code first..
and then take and refill or whatever...
And then when you put it back....do it when power code is unplugged as well.
Personally, I refilled and used CL831 more than 8 times..
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 19, 2011 | Canon PIXMA MP150 All-In-One InkJet...
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
Colored refill ink cannot be recognized
It is called e5 error.
For Canon cartridges, after 4~5 refills, the color cartridge cannot be recognized by printer.
In this case...there is no solution so far...just replace with new cartridge.. that's it.
(To avoid e5 error, you need to make sure "plug out" the power, before take out your cartridge for refill. Yes... "plug out" the power cords!!!!
May 06, 2011 | Canon PIXMA iP1300 Printer
Error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Apr 27, 2009 | Office Equipment & Supplies
Refilled Cartridge
How can I Reset Memory For Lexmark X4550
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
I have an error 5A in my dcp-110c
Jan 04, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
8,301 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
