Brother DCP-110C All-In-One InkJet Printer
I have an error 5A in my dcp-110c
shared by 2 users
posted by dr3w on Jan 04, 2008
i had this printer for quite some time already and had its cartridges refilled. now i tried to test print it but it won't. i get this error 5A when in maintenance mode what does this mean. i also get a cranky noise inside the printer when start black is pressed or to print for that matter. then it says scanner cover is open, sometimes a paper jam that does not exist. please help me w/ this...
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Guest on Jul 12, 2008
I just got it and it scans but it keeps saying i have a paper jam when there is not one. how do i fix this?
Solution #1
posted on Jan 21, 2008
Thanks for Trying (70)
bowdo
Rank:Guru Guru
Rating: 89%, 108 votes
Purge unit error. Check for a piece of paper in the purge unit - right hand side of printer where the carriage sits. Trick the machine by powering off while carriage is moving and check for paper under the cover. If no paper there is a problem you can not correct and you need to get it serviced.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on i have an error 5A in my dcp-110c:
I don't want to Accept this solution
Can you Help with these Printers problems?
How do I change the scan settings in order to scan...
I need to scan something that needs to be less than 1mb....
small screen on printer shows data remaining
printer is "ready" on the control panel with a...
what do i do it says its unable to print
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
