Heart Rate Monitors
Problem for Heart Rate Monitors
Generic problem for all Heart Rate Monitors
Sportcraft Heart Rate Monitor - Tra...
By johnpwalker on Nov 04, 2009
Since Sportcraft no longer replaces batteries in their heart rate monitors, I'll need to know how to do it myself. The receiver/watch has screws on the back, so this will be no problem. However, the transmitter that straps to the chest has no outwardly visible means of case separation. There is a front nameplate that may grant access, or two pyramid-ish shaped inlays on the back, one at each end near where the pick-ups are, although there is no place to insert a tool to pry them out to access any fasteners. The case halves are so tightly mated that I doubt simply prying them apart will work without damaging the unit. I don't have a strong, miniature vacuum device, so I was thinking about super-gluing a handle of sorts to the inlays on the back to pull them out, assuming that they are merely press-fit in. But, then, cleaning up the glue with acetone thereafter is sure to dissolve the plastic, rendering the unit non-watertight, as would any drilling. Sportcraft did suggest possibly taking it to a jeweler, so what I need to do can be done with the ''right'' tool(s), but I haven't a clue what it/they might be. Aside from chucking this one, and buying a new unit, has anyone any ideas? Thanks.
Popular Solutions for Heart Rate Monitors
Questions and Unsolved Problems for Heart Rate Monitors
Answer
How do i look at my calories burned during exercising?
Answer
My Lifespan treadmill tr2500-hr motor will not run,I get a error after about 5 seconds unless I... (More)
Answer
how do you replace the battery? Cant figure out how to open it.
Answer
I have an IF 3Wave tens unit beeps 3 times on power up and the LED does not light up - why?
Answer
i need instructions on how to use my proform precision xt heart rate monitor to track calories... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heart Rate Monitors:
Top Heart Rate Monitor Experts
Rank: Guru Guru
Solutions: 3902
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Heart Rate Monitor Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
