Question about HP OfficeJet G85 All-In-One InkJet Printer
Long pauses very very long pauses between printing each line ?
    President:
  • 4,402 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=us&dlc=en&product=60399&rule=45205&lang=en
Posted on Jan 15, 2008
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Will not print under OSX 10.7
QMS is a legacy company under then Minolta, now Konica Minolta I believe page pro 9100 is very old I believe that it would work with windows 95 or xp at best.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 13, 2011 | Minolta QMS PagePro 9100 Laser Printer
JAM LABEL
1. Turn the printer on and make sure that the LCD display reads 'ON LINE'.
2. Press the PAUSE key once. [The display will read 'PAUSE'.]
3. Press and hold the PAUSE key until four or five labels feed forward.
NOTE: On some models, pressing the pause key will change the LCD display to 'TRANSMISSIVE'. If this happens, repeat step 3.
4. Press the RESTART key. The printer will go back ON LINE.
5. Open the print head and reposition your labels, so that they are ready for printing. Close the print head.
Nov 17, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
After pausing a printing job, my printer has gone offline
Go to Printers & Faxes, open your printer (the window where you see the documents being printed), and from the upper menu leftmost item (Printer) uncheck the option "Work offline" or similar. Then try resuming or restarting print.
Jan 30, 2010 | HP DeskJet F380 All-In-One Printer
Lq2180 when print few lines, the printer pause light on, press pause button print again, than pause again, need to stand there and keep pressing pause light
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Dec 22, 2009 | Epson LQ-2180 Dot Matrix Printer
Printer keeps pausing itself!!
By UI do you mean RUI (Remote User Interface)? Have you installed a network kit? If so did you upgrade firmware using SST? If not, you need to do this or printing won't work.
In service mode. Copier > Display > Version > PS/PCL there needs to be a number e.g. 30.06. If there is no number the copier does not have any print drivers on it and won't be able to print. You also need to have a N BOOT-ROM (included in network kit). There Should be a N next to the number for BOOT-ROM under Copier > Display > Version if a N BOOT-ROM is installed.
Jan 14, 2009 | HP LaserJet 3330 All-In-One Printer
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Printing but not able to read bar code with scanner
make the pause test (press pause and turn on) press Pause , 5 sec. if print qualiti is ok and you dont see some lines across the print, the problem is not the printer.
if you see some withe lines across the print, you need to replace the print head.
Apr 15, 2008 | Zebra Z4Mplus Label Printer
Can't get barcodes to scan?
have you tried different darkness settings? it sounds like you only need to turn the darkness up a little.
Apr 02, 2007 | Zebra 110XiIIIPlus Label Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
