Question about Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLR5667W lamp replace
My lamp burned out and I replaced it, no problem, but now I have a greyish/black vertical stripe on the far left side of television about 2 inches wide. Is there any way to adjust this?
Thanks!
  • AnnRuss Jan 08, 2008
    I have a Samsung HLN437WX 43" with vertical dark shadow on right with loud buzz saw noise. Replaced color wheel. Now have lighter shadow on left and no noise. Thought light engine might be problem, but since the shadow changed sides (right side is clear, good color), I'm wondering if I should get a lamp replacement. I've had the set 4 years with no previous replacements of any kind. Thank you.
  • lgurol Feb 10, 2008
    I have the exact same issue that ididitmyself described above. I have a vertical gray line shadow that is hindering the quality of the image for a few weeks. My TV's model number is HLR5667. It has been 25 months since I bought it. Any help resolving this would be greatly appreciated. I hope that Samsung representatives read these posts and take corrective action to their products and assist us in guiding us to resolve this issue. This is negatively reflecting on their image in the eyes of consumers.
It's really easy too move the light engine just enough to cause this problem when replacing the bulb and really likely when changing the color wheel.
The only way to fix it is to take the whole back of the set off and loosen the bolts holding the light engine in place then move it around until it's exactly centered.
Posted on Apr 30, 2008
    Problem Solver:
  • 7 Answers
The Problem you all are describing is a faulty light tunnel assembly it is common on most DLP projector sets.
Something I would not recommend attempting if you don't have the skills, It involves taking apart the optical system of the engine, you could have it repaired from an authorized service center for under $400.00.
Posted on Feb 24, 2008
I gave up ... bought a new Sharp LCD and had the Samsung hauled away. The local stores aren't even selling the old rear projection sets any more ... and Samsung was NO HELP ! Enough already!
Posted on Feb 12, 2008
Posted on Feb 10, 2008
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My Viewsonic N3751W lcd TV has a @2" vertical
you need to clean the vedio connector properly inside your tv , if you dont have good idea about electronic you need a technicien
Dec 29, 2010 | ViewSonic N3751W 37 in. LCD Television
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Display has 2 inch black stripe running vertically down screen
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Dec 26, 2008 | Toshiba Satellite P105-S6104 Notebook
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Hp r4252 white vertical stripe on left side, 5 in wide
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
Jan 30, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
979 people viewed this question
Jerry Greenberg
Jerry Greenberg
