Question about Indesit 24 in. DE73 Evolution Free-standing Dishwasher
Indesit d73 errora 08
Indesit evolution de 73 error code a08. wash program 25min seems to finish ok, with "end" being displayed.other programs error a08 occurs.
  • Anonymous Mar 19, 2008
    AO8 error code as well. Washes ok up to last 70 mins to go stops and flashes AO8 Help!
  • Anonymous Jul 16, 2008
    On setting 3 (After Dinner) always ends with error: A08 Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30". Not sure what this means as seems to wash well and heats up, but stops before drying!
4 Suggested Answers
  • 4 Answers
SOURCE: indesit evolution de 73 dishwasher with an AO5 error code
a05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
Posted on Jul 28, 2007
jharvey572
  • 447 Answers
SOURCE: indesit dish washer is showing
from what i can find out, it means (auxillary wash pump triac cloesd/open circuit)
Posted on Sep 25, 2011
ginko
  • 19396 Answers
SOURCE: sulla mia lavastoviglie indesit de 74 evolution mi appare il codice di errore a12 mi sapete dire cos'?. Grazie in anticipo Fabio
Ciao Fabio.
A12 significa che c'e' un problema con il circuito di riscaldamento dell'aqua. A12 appare quando il modulo di controllo rileva che il circuito che include l'elemento e'aperto.
Elemento e circuito devono essere testati con il multimetro. Se l'elemento e' aperto deve essere sostituito. Se i cavi e l'elemento sono a posto, allora il problema e' il relay integrato nel modulo di controllo.
Il caso piu comune consiste in un elemento diffettoso.
In bocca al lupo.
G.
Posted on Dec 08, 2011
What does code F-10 means?
F10 is a pressure switch fault which could just be the pressure chamber is blocked and needs cleaning out
use this link for error code Domestic Appliance Help
Oct 03, 2016 | Indesit Washing Machines
Indesit dish washer is showing error code A08 why
Sep 25, 2011 | Indesit 24 in. DE73 Evolution...
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Indesit 1200 evolution washer displaying an F04 code.......... washer has stopped without rinsing or draining. any ideas?
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 12, 2009 | Washing Machines
Indesit dishwasher DE73 error code A08
A08 - Open/Short circuit auxiliary wash motor triac -
Hope this helps
Apr 06, 2009 | Ariston Technologies Dishwashers
Indesit evolution we 123
Hi.
the error code means that the heater relay is not working.
You will need to call an engineer.
If you call hotpoint, it will cost you over £100-00.
Better to call a independant if you can find a good one.
Nov 19, 2008 | Indesit W 123 Front Load Washer
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit DE73 showing A08 fault code
Sounds like it has overflowed at some stage. Ensure the filter is cleared and then rock the dishwasher backwards. Any trapped water will drain out and the safety valve will reset. i had similar and this was what the indesit technician did.
May 21, 2007 | Indesit 24 in. DE73 Evolution...
Indesit evolution de 73 dishwasher with an AO5 error code
May 06, 2007 | Indesit 24 in. DE73 Evolution...
A13 error code
It seems to me that there isn't any problem with the normal washing cycle. The problem you have could be related to your dishwasher's detergant dispenser lid. I reckon that the relevant part isn't functioning normally. You can simply check out the claws placed on the detergant lid. If there is a spring inside, it might be damaged.
Apr 16, 2007 | Indesit 24 in. DE73 Evolution...
Indesit 24 in. DE73 Evolution Free-standing Dishwasher Logo
66 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
