HI, the water inlet valve should be inspected for damage, or clogs at this time . This will be the culprit.(check for frozen lines as well)
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 22.4 cu. ft.
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with...
My new Kenmore Elite front loading washer (model 46742 - HE3t) draws in hot water when I want to run...
(More)
My new Kenmore Elite front loading washer (model 46742 - HE3t) draws in hot water when I want to run a cold water wash and vice versa. The repair technician ordered a new wire harness and will run an electrical test on both existing and new harnesses when to determine if the wire running to the hot water inlet is at the same at the cpu/board for both harnesses. If it's not the harness, it may be the cpu. Sound like a good troubleshooting plan?
beeping wont stop. Need simple solution to stop beeping. Two days of non-stop beeping. Seas wants to...
(More)
beeping wont stop. Need simple solution to stop beeping. Two days of non-stop beeping. Seas wants to send a tech out for a charge because we have no warrenty.
I have a 5 year old Kenmore Elite Trio w bottom freezer. The refrigerator is not cooling but the...
(More)
I have a 5 year old Kenmore Elite Trio w bottom freezer. The refrigerator is not cooling but the freezer is fine. The fan seems to be running okay but the refrigerator is warm not cold. Any ideas?
my fridge/bottom freezer stopped getting cold and the are now at room temp feel slight coolness from...
(More)
my fridge/bottom freezer stopped getting cold and the are now at room temp feel slight coolness from both fans but not enough to cool appliance.
