Refrigerators
Generic problem for all Refrigerators
Hotpoint mistral plus 8596
shared by 3 users
posted by celticboy on Jan 04, 2008
fridge is overheating currently at 18 centigrade
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by madmanc on Sep 06, 2008
The temp of fridge varies from 4 degrees raise to around 13 then after a while drops again, Door seemed to be sagging have added washer this worked for a while also pulled off grill at bottom of freezer and removed lots of dust.
Posted by Itchy Bush on Aug 17, 2008
Have Hotpoint Minstral Plus Frost Free fridge freezer. The high temp light keeps coming on & going off on a regular basis!
Best Solution
posted on Jan 11, 2008
Helpful (85)
WASHDOCTOR
Rank:Guru Guru
Rating: 87%, 185 votes
IF the freexer is working fine then the evap thermistor is gone..
pretty cheap at around a tenner and easy to replace.. its located in the freezer section behind the panel near the top
remove all the freezer draws.. then remove the six screws to the back panel... remove the panel and its the yellow senor remove it and replace it exactly where it was plugged in and also attached to the evaporator.. the freezing section...
if both are not working then its the fan .....
at the back when the motor is
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on hotpoint mistral plus 8596:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Whirlpool GS6NBEXR Side by Side...
The inlet hose going to the filter is leaking at the...
Refrigerators
I noticed the meat in our freezer was starting to thaw...
Refrigerators
refrigerator is not freezing and not cold as it use to be
Frigidaire FRS3R5EMB Side by Side...
my refrigerator is not cold as it use to be and is not...
Kenmore 53642 / 53644 Side by Side...
My 5yr old Kenmore Elite refrigerator's warranty was up in...
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
