Philips dvd player model dvp 3110k
To whom it may concern:
My dvd player model philips dvp 3110k the factory setting had been reset and i can't configure how to set it back to its normal setting. Please help me solve this problem. Kindly e-mail me mckoy21_14@yahoo.com for your answers.
Thank you and God Bless!
    Novelist:
  • 189 Answers
Make sure playback on any loaded DVD is stopped.
Press 'Setup' on the remote.
Press < > to select 'Preference Page'
Press <up> or <down> to select 'Default'
then press > to select 'Reset'
Press 'OK to confirm.
This will reset all settings to factory defaults except for 'Parental' and 'Disc Lock' settings.
Here's a link to the User Manual in case you don't currently have a copy. The information above is from page 38.
Posted on Jan 04, 2008
  • 36 Answers
Im assuming you're looking to restore to default settings.
http://www.p4c.philips.com/na4/d/dvp3140_37b/dvp3140_37b_dfu_aen.pdf
I couldnt find your exact model, so i got one as close as i could. On page 38 of this manual, there are instructions on how to restore to original settings. Try it out, and report back >.<
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
My philips dvd player 3266 asking for a password.
You'll have to update the firmware with the instructions here. After you've done this, you can access the settings menu, choose reset to default all settings.
Nov 24, 2013 | Philips DVP 3260 DVD Player
I have a Phillips DVD player model DVP 3962/37 password
the factory password for my dvd player is 136900 but i too have this problem. i do not know how to disable the password
Feb 27, 2010 | Philips Televison & Video
How do you make a philips dvd player model no dvp 5990 region free ???
Philips DVP 5990
How To Make Region Free:
press Setup
select the Preference Tab
Press 1 3 8 9 3 1
Press up/down key to select "0"
and press Setup to exit.
If you can't get into Preferences Tab, you may need to press the stop button twice first, then press setup.
Sep 17, 2009 | Philips DVP5990 DVD Player
I HAVE A DISC IN U.K. AND EUROPE REGION . BUT CAN'T PLAY MY DVD PLAYER. HOW CAN I PLAY THE DISC IN OUR PLAYER? MODEL IS DVP 3256 ,DVP 3258,DVP 3268 . WITH USB . ANY OPTION TO PLAY THE OTHER REGION DISC....
HELLO
This sounds like the old problem of your player trying to play a disc from another region, when your player is set for another. What you need to do is HACK the player and set it for ALL REGIONS (0), usually via the remote control.
Try this website for DVD player hacks: www.videohelp.com
You will find hacks for many makes and models listed here. Contrary to belief, it is NOT illegal to hack a DVD player.
Aug 03, 2009 | Philips DVP3960
Hi benimur
Appreciate the direct "Ask Me",.
There might be more than 1 version of this player depending on country of origin or intended marketing region hence the solution posted that you are referring to might not be applicable to your concern.
Offhand, I would suggest that you try a hard reset, that is unplug from the mains for an extended period of time (perhaps even overnight). The idea is to dissipate whatever residual power is inside the unit and hopefully thereafter, it will revert to factory defaults. Then try again. On the first power ON, wait till "NO DISC" is displayed, then try a known good disc. Alternately, you can also try, unplug, wait for a minute or so, press & hold the STOP button, plug the unit to the mains. You can also try that with the other buttons.
Should the above be not corrective, am afraid that the a firmware update/flash/reset is required by an authorized service center.
Hope that this be of initial help/idea. Pls post back how things turned up or should you n
Oct 12, 2008 | Televison & Video
DVD dvp 3120 is currently zone 4. Would like to make it multi zone
1) Go to Setup page
2) Preference page
3) Press 138931
4) Press up/down key to select region code
Sep 13, 2008 | Philips DVP5140 DVD Player
Region Free Code: Philips DVP 5980
this worked perfectly, thank you!
Dec 19, 2007 | Televison & Video
526 people viewed this question
 Grubhead
Grubhead
