Question about Xerox Phaser 7300DN Laser Printer
My Phaser won't print, even though other machines on the network are fine?
We have a networked phaser 7300 and none of our macs can print to it. We can hook up to each other and print to a different printer also on the network, just not the Phaser. We get and 'waiting for job to complete' message or 'printer not responding' . We are told to switch on apple talk, which already is switched on? We have been printing to the machine for 2 years, and suddenly there's nothing?
    President:
  • 2,072 Answers
I will start not knowing what you have already done but, here goes.
Start first by looking at the port on the printer where your ethernet cable is connected. Look for the green power light, see if its illuminated. Then look at the data light to see if its flashing.
It it is not, check the port and the cable running to the machine.
Have you plugged another printer or device in to the same port that the printer is on to check its functionality? Can you enter the IP address into your Browser,and pull up the printers properities on the browser.
The other thought is that the settings were on Auto in DHCP and the machine changed IP addresses. Do you have a saved configuration page on the machine that tells you what IP address was assigned to the machine? If so, print another Configuration page and compare IP addresses. If you have to reset. Set IP to Manual. And set a static IP address.
Either a dead port or an addressing problem seems most likely.
It's far less likely, although possible that one of the machines boards are bad. Or a hard drive has failed internally. But most of the time when that happens, the machine senses it and gives a fault code indicating what network problem has occured.
You can also check the job status button, see if there is a job hung up as a held for resources, if someone sent a print job with the wrong paper size ot type selected it may be backing up the printer waiting for that specific media to be loaded. Once you delete that job, It will print previous jobs.
Supplies are a possibility, but you should see a message to replace whatever item is low or out.
I do suspect, one of the first 2 issues, a dead port due to the port or cable, or an address change on the machine. That really sounds like the most likely issue
Posted on Jan 04, 2008
Phaser 8560 wont print
I've had my HP do this a lot with my Probook. Sometimes I have to turn my printer on manually even though the light is on, it sometimes go into a sleep mode. Maybe your printer does the same.
Also, have you made the printer your "defaul" through control panel settings? Just a few ideas.
Feb 11, 2013 | Xerox Phaser 8560MFP Laser Printer
Phaser 7300 dn prints full yellow color background on every page even if the background copy shows no color.
Most likely the yellow drum unit is causing that problem. The charge roller gets worn and makes whatever color it is in print out all the time. That would require replacing the yellow imaging unit.
Feb 20, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 jamming manual feed
Can you print fine with no jams from the lower tray?
make sure you have clean new paper and start out with the 11"x8.5' letter paper. If you have that then follow the instructions below.
  1. Make sure there is no peaces of paper jammed in the path.
  2. clean the rollers with regular rubbing alcohol sometimes the rollers get way dirty to pick up the paper.
  3. If none of these tricks helped you then you have to change the the manuel feeder. part # 116-1561-00 good luck.
Dec 07, 2009 | Xerox Phaser 7300DN Laser Printer
Installation of Phaser 8550 DP on network
This is no problem for someone with even a little networking knowledge, but it would take longer to write the instructions here, than it would to have someone spend less than an hour configuring it on site. That's my recommendation
May 19, 2009 | Xerox Phaser 8550DP Printer
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
Error message
Cause:
This message is related to the on-board SRAM on the Print Engine Control Board Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Replaced the Print Engine Control Board,
Dec 19, 2007 | Xerox Phaser 7300DN Laser Printer
Does not recognize second tray
Is it not recognizing the second tray from the print driver or from the configuration page that prints
Oct 25, 2007 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
190 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
