Hitachi Plasma Television 55HDT52 Has Sound but no picture When I change the channel the sound changes but the screen does not light up
Comments:
Nov 05, 2009
- X or Y Boards have no heat on any of the heatsinks I don't have a circuit diagram for this so I don't know the voltages you are supposed to have. Two of the heatsinks on the power supply board are cold to the touch. Thanks for your help.
55hdt52 plasma - have no picture or sound - green power light flashes 10-11 times but will not power...
(More)
55hdt52 plasma - have no picture or sound - green power light flashes 10-11 times but will not power on
I have the EXACT problems that J has......the TV will power but only black screen with audio. The TV...
(More)
I have the EXACT problems that J has......the TV will power but only black screen with audio. The TV (55HDT52) started blacking out. Would unplug and plug back in and the TV would work again. Several months later the TV screen went black and now only audio works. Did you ever get yours repaired? What was the culprit? Thanks Joe
Hello! I have a Hitachi 55HDT52 plasma television and it up and stopped working on me today. The...
(More)
Hello! I have a Hitachi 55HDT52 plasma television and it up and stopped working on me today. The television is roughly 2 1/2 to 3 years old. I have had no problems with it until today. There were no advance warning signs at all leading up to this. I just watched a blu-ray on it last night and the picture and performance was flawless. This afternoon the tv was on and without warning it tuned itself off. Even the standby light is not responding. It basically is acting like it is not plugged in at all. I tried swapping out the power cable and tried another outlet on the off chance that might fix it. Everything else plugged into the surge protector appears to be working fine. I have come to the conclusion that I may be forced to track down an authorized Hitachi repair center and pay what I imagine will be a pricy repair bill. I was hoping that maybe someone has heard of this issue before and might have a suggestion. Thanks.
Hi Bradley_64 I have the very same problem the only difference is I didn't use the blu-ray. I watched tv last night into the early morning, I fell asleep, the tv went off and this morning I can't turn the power on except thru the reset button thered light wil come on,then green blinking light then off again...PLEASE,PLEASE, PLEASE HELP ME...I don't have very much money, just went thru a very bad divorce. thanks in advance heavenlyscents58
My Blu-ray player with HDMI connection to my HDTV shows S-IN:2 instead of HDMI and therefore no...
(More)
My Blu-ray player with HDMI connection to my HDTV shows S-IN:2 instead of HDMI and therefore no signal reaches the HDTV. I changed a setting on my player to 1080p and since then the problem as I described above. Thanks.
