D-Link RangeBooster G  WBR-2310 Wireless Router
Problem for D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
I had some1 set up my dlink so i dont know what my
By jaada711 on Nov 04, 2009
i had some1 set up my dlink so i dont know what my username and pass is and i need to open some ports how can i do this?
Solution #1
posted on Nov 04, 2009
Not Rated)
niceguy_202
Rank: Guru
Rating: 86%, 193 votes
you need to manually reset the router to its factory settings. To do this, look at the rear part of the router and look for a very small whole with a small pin inside. press that pin down using a stick for 30 seconds to reset. resetting means losing all info and settings so make sure you have the IP configurations of your ISP but you can call your ISP to get these. And when reset, the username is admin and the password is blank OR try the reverse: username is blank and password is admin. You can try it now without resetting maybe the technician left the default settings unchanged
Was this helpful?
Yes
No
Solution #2
Not Rated)
krishmaqvan
Rank: Guru  D-Link Computer Networking  Expert
Rating: 86%, 201 votes
For that connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" or blank or "password"
Then you can see configuration page of router then if you want topen port click on port forwarding or NAT.
Then change as you want.
then save and restart router to take effect.
Let me know if you need further assistance.
thanks.
Was this helpful?
Yes
No
Popular Solutions for D-Link RangeBooster G
Questions and Unsolved Problems for D-Link RangeBooster G
Do you recommend D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)?
Answer
Answer
I do step #1 and #2 then # 3 fails to locate router. Why? I have reset router several times but... (More)
Answer
Hello, I have the router D-link WBR-2310. I managed to set up my notebook in order to access the... (More)
Answer
hi i have a d-link dsl g684t router i was updating the firmware and my pc turned of now i can acces... (More)
Answer
Clarification: I have the ssid set and can access the internet, just can't access the linux file... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For D-Link RangeBooster G ...:
Top Router Experts
Rank: Guru Guru
Solutions: 3659
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
