Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Inspiron 5150 contact problem
What can be the problem with a Dell Inspiron 5150 when you have to give it a tender pressure with your thumb/hand on the cabinett, near the pointer device/mouse, in order to keep the power on? It will not work without this pressure. Any ideas?
    Genius:
  • 1,601 Answers
Without looking at your laptop, it is hard to tell.It could be a bad solder joint or loose part inside.
Here is the manual for your 5150:
http://support.dell.com/support/edocs/systems/ins5100/en/sm/index.htm
You can look at the place where you apply pressure, and should be able to tell what the problem is.
Posted on Jan 04, 2008
DELL INSPIRON WILL NOT ACCEPT WINDOWS 7 i GET ERROR n0_MORE_IRP_STACK_LOCATIONS
Was the hard drive contain any previous operating system? If it was, then you need to chose "Delete the volume" and "Format", and let's see the result after you reinstall the Windows 7.
Mar 04, 2014 | Dell Inspiron 5150 Notebook
Some of the keys on keyboard stopped working
Yes replace the keyboard. It is usually not a hard job so have a look here < LINK
Best of it.
Thanks for choosing Fix Ya
May 29, 2010 | Dell Inspiron 5150 Notebook
Blank screen on start up. No dell logo. Only
have u tried resetting it (u may loose it all)
Apr 14, 2010 | Dell Inspiron 5150 Notebook
I have a Dell 5150 Inspiron. I am able to connect
Contact your ISP(internet service provider)
Jul 13, 2009 | Dell Inspiron 6400 Notebook
Black sreen with flashing underscore
Try pressing "esc". If it doesn't help call the dell technical support hotline. Or ask the shop.
Good luck
Jun 26, 2009 | Dell Inspiron 5150 Notebook
Dell inspiron 5150 green light flashing on front won't boot up
I had the same problem, replaced the hard drive and problem went away. The hard drive developed bad boot sectors after downloading XP service pack 3. I found out later it isn't compatable with the dell I have. Hope this helps. Good luck!!
Apr 29, 2009 | Dell Inspiron 5150 Notebook
Inspiron 5150 fan continously running
Dell Inspiron 5150, has overheating problems. The position of the fan is a problem.Also,don't press of the left upper corner of the laptop.Here's an excerpt from a wikipedia article: "The overheating problems on the Inspiron 5150 model was due to the position of the fan and fan-vent and the way in which it vents air through the CPU's heatsink.[citation needed] The fan draws air from underneath the unit and vents it through the rear after passing over the heatsink. However, the unit also sucks up dust from underneath it. Over time a buildup of dust constricts the airflow through the unit, reducing cooling. The airflow is perceptibly diminished. A simple test is to place a hand near the fan vent; when the fan is running at high speed there should be a good flow of warm air. Heat will also build up along the top of the unit near the LCD display and left toward the optical drive. Users may notice this while typing. Performance may also suffer, with jittery game movement and slow Windows performance. Some systems may experience jerky reactions where the unit goes into an almost slow-motion phase for short periods of time. Continued operation in this condition may lead to overheating and could result in permanent damage to the CPU, GPU, motherboard and other internal components. To remedy this the unit must be disassembled, the dust removed, and fan operation checked. This problem not uncommonly results in a CPU temperature-increase of between 15-20°C over an normally functioning unit. Further temperature increases may damage the casing of the unit."From Wikipedia article"Dell Inspiron" under problems Hope it helps -CG
Jan 20, 2009 | Dell Inspiron 5150 Notebook
Hi there, need help with dell inspiron 5150 dark screen, please help????
If you can see faint images on the LCD and you can connect an exrternal monitor and get a normal display, the issue is a failed LCD backlight
Jan 14, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 power jack is bad
Contact www.e-techsiliconvalley.com
They are laptop repair expert. Give my name (Farhang) as reference and ask for help.
Dec 01, 2008 | Dell Inspiron 5150 Notebook
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
130 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
