Question about Toshiba Gigabeat U202 MP3 Player
Gigabeat u202 sl, winXP sp2
On 2 different pc's, my new gigabeat U202 sl, is not recognized. It looks as if it is starting to show the green charge symbol, then turns orange. Windows says usb device is not functioning. again, windows XP sp2 on both machines. The gigabeat worked great the first time I loaded it. This only happened when I tried to connect to change the music.
I tried reset. I formated the data. Still nothing, same problem.
The device charges fine using the toshiba wall/usb adapter unit.
  • 1 more comment
  • Elginengine Jan 07, 2008
    My U202 does exactly the same thing as above out of the box. I rebooted with the u202 conected and now it is charging, The FM radio works great but I think I need soft ware that i don't have to load the unit.
    I have downloaded windows media player 11 off the disk that came with the unit. But still can't seem to figure out how to d/l mp3'files into it. pls. help?
  • Anonymous Jan 20, 2008
    I have the same problem too...
  • allenpol Feb 16, 2008
    yes i have the same problem how can we fix it pls help us!!
I have a similar problem. I bought a new gigabeat U 2Gb in USA last week. It functioned properly in computers in USA. Now I'm in Argentina and I can't connect it to my computer (windows XP and windows media player 10 both in spanish)I tried install WMP 10 in english that came in the CD and the other
two files windowsmedia10-kb902344-x86-intl.exe and windowsmedia10-kb895316-x86-enu.exe and in the last case apear this message:
"Setup cannot update your WMP 10 files because the language installed on your system is different from the update language". Do you have any suggestion to solve my problem? Thanks
Posted on Feb 26, 2008
Gigabeat room fails to recognize my Gigabeat
transfering is not a a problem its a player problem have  you ever format your mp3 player?
Dec 16, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Oct 30, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
How do you make playlists
I had the same problem. Once you've bookmarked songs (using the squiggly button on the right), go into "library" (using arrow button on the left), then enter (middle button), down to "bookmark", enter, then "favourites 1" (for example), enter, "play all", enter. This will play what you've bookmarked in order.
As for "playlist".... I'm still stumped, but this should do instead!
Oct 11, 2008 | Toshiba Gigabeat U202 MP3 Player
This Worked For Me!!! Check this link it is the only thing that fixed my "no system found" problem. This guy really did his homework.
Sep 24, 2008 | Toshiba Gigabeat MEG-F10K MP3 Player
I have a Toshiba Gigabeat F60 from several years ago. It stopped working shortly after I got it and now I would like to try to get it working again. Upon start up it says "no system found oh HDD" but my...
The Gigabeat is not recognizing the firmware on it. The easiest way to re-install the firmware is to install Gigaroom. It will be able to recognize the Gigabeat and replace the firmware.
Apr 06, 2008 | Audio Players & Recorders
Driver files for Toshiba Gigabeat MES30VW
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Feb 28, 2008 | Toshiba gigabeat S MP3 Player
Help us pls!!
Plug it into a pc, transfer mp3 files to it, unplug. insert headphones, press play.
Now.. what doesnt work?
Feb 16, 2008 | Toshiba Gigabeat U202 MP3 Player
Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat U202 MP3 Player Logo
152 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
