Coleman Propane Forced Air Heater w/Electronic Ignition
Problem for Coleman Propane Forced Air Heater w/Electronic Ignition...
Read the instructions on how to light the pilot
By amyjo1028 on Nov 04, 2009
read the instructions on how to light the pilot but where I need to put the match I am not sure where to direct the flame to. I see the housing for the pilot but not where inside
Solution #1
posted on Nov 04, 2009
Not Rated)
shastalaker7
Rank: Guru  Air Conditioners  Expert
Rating: 90%, 66 votes
You noted above it is a Coleman forced air Heater with a electronic ignition? You don't need a match to light the pilot, it lights automatic on a call for heat at the thermostat.If it does not light, then you have other problems. Let me know.
Good Luck,
Shastalaker7
Was this helpful?
Yes
No
Popular Solutions for Coleman Propane Forced Air
Questions and Unsolved Problems for Coleman Propane Forced Air
Do you recommend Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)?
Answer
Answer
hi, i have a el wagon and the centeral locking ,keeps going up and down, have not found a solution... (More)
Answer
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble... (More)
Answer
evertime we lower thermostate at night then raise it in the morning the resit light is flashing then... (More)
Answer
i have a pro comp pc9001 distributor multi-spark box with a pc91 coil..my problem is where does the... (More)
Answer
when i open the window of my car than the locks starting up and down regularly and when i start the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coleman Propane Forced Air...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
