Canon NP 6050 Copier
Problem for Canon NP 6050 Copier
Blank copy just plain white paper
By cindyalvarez on Nov 04, 2009
blank copy just plain white paper
Comments:
Nov 04, 2009
- Can I know what dev is?
Solution #1
posted on Nov 04, 2009
Not Rated)
Soulvisitor
Rank: Guru  Canon Expert
Rating: 88%, 2355 votes
toner, charge or dev not in position or of cause we could go for upside down original, my guess toner 75% Carona/charge roller 20%, 4% Dev unit outa position, 1% blank original.....hows that for 20 years summed up on white paper;)
Comments:
Nov 04, 2009
- Sorry dev is the developer unit, it carries the toner to the drum, it takes the toner from the hopper via a cockscrew mechanism and deposits it on the drum via a magnetic roller. No developer turning or not in contact with drum can cause blank prints.
Knowing if it happened after jams or was grey now blank or suddenly blank sorta helps as does reasurance that it has toner...cheers
Was this helpful?
Yes
No
Popular Solutions for Canon NP 6050 Copier
Questions and Unsolved Problems for Canon NP 6050 Copier
Do you recommend Canon NP 6050 Copier?
Answer
Answer
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is... (More)
Answer
switch power off and on again EO50
Answer
we are getting continual jams in areas 4 & 5 even though there is no paper to remove. any... (More)
Answer
i want a copy of manual and troubleshooting.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon NP 6050 Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
