Question about ASUS M2N-MX Motherboard
Audio problem Microphone is not working. give error Wrong device connected.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Check the PINs for Front panel on motherboard and use jumper as suggested in the Manual.
like murcury uses 5-6 & 9-10.
Posted on Jan 04, 2008
Helpline
The guide fro properly connecting your microphone is here
GarageBand 11 Connect microphone
The problem is with OSX and its usb bus and not your settings or your usb device.
The solution to your problem is to use a firewire soundcard. That way it will use the firewire bus and all should be fine.
Feb 15, 2014 | Computers & Internet
After installing windows 7 on my hp compaq dc 7600 CTM, the audio deives case to cme. But when connect with a extenal speak it comes. But the microphone can't contigure. Or can't work.
Hi.
Start > Control Panel > Sounds and Audio devices > Audio > use drop down arrow to reveal list of audio devices and select the correct default audio device > apply > ok.
For the microphone, connect the microphone to the pink audio socket front or back > right click on the speaker icon bottom right near the clock > audio > recording devices > double click on micrphone icon > check settings.
i hope this helps.
Aug 24, 2011 | HP Compaq dc7600 PC Desktop
I am not getting any sound from desktop speakers..i have sony driver installed
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
Mar 06, 2010 | Office Equipment & Supplies
I CAN SEE OTHER PERSON AND THEY CAN SEE ME BUT CANT HEAR ME BUT I CAN HEAR THEM .WHAT HAVE I DONE WRONG
The problem is either the microphone is not connected/faulty or the wrong microphone is selected in the Skype Audio setting.
To check if the microphone is working - go to Start - All Programs - Accessories - Entertainment - Sound Recorder and do a test recording.
If the sound is doesn't work then open Device Manager - Sound, video and game controllers and check the microphone is enabled and working. If it isn't listed or has a yellow ? against the microphone then you need to install the microphone device driver.
If the microphone is working then open Skype then click on Tools tab -then Options - Audio Settings - then in microphone setting and click on the microphone list to select your model microphone. Then Save your settings.
To test your microphone settings then go to Contact list and select Echo / Sound Test.Service and follow the instructions. If this works then your friends will be able to hear you,
Nov 07, 2009 | Logitech Quickcam Chat Webcam
I have a microsoft webcam vx5000, i set it up on my computer. The video works on skype, but the microphone will not work? Is there something wrong with the camera itself?
i dont think so there is problem with ur camera relating to the microphone .....
check from if correct device is selected
start---settings---control panel click on sounds and audio devices and check under tab audio and voice if ur proper microphone is selected.
regards
All the best.
Oct 26, 2009 | Computers & Internet
I CANNOT GET THE MICROPHONE WORKING
This could be due to several reasons -
> Faulty microphone (something could be wrong with the device, or the input jack) - Try using your microphone on a friend's PC. If it is working fine, then proceed to the next line.
> Incorrectly installed sound card - Have you installed the sound card and its drivers correctly? Update your sound card's drivers, and then give it a try with the microphone.
> Go to Control Panel->Sounds and Audio Devices. Go to Audio tab, and in the Sound Recording  section, check whether your sound card is selected. Click on Volume button here, and ensure that Microphone is "Selected". Do the same with the Voice tab too.
Dec 25, 2008 | Computers & Internet
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Microphone
Open system properities. click hardware tab & than device manager. Scoll down to Sound, video & game controller. Do you see a yellow ! point there. That means the driver may need to be reinstalled. Asus is famous for having defective mic controllers & yes the sound works but no mic. You can also open control panel open sound & audio devices. You should have the same device under Audio & Voice. If you do, again your intergrated mic controller is bad. Your manual most likely will not have the correct number to call tech. They moved in 07. So I'll put it in here: 812-282-2787Tech IL Eastern Time. Good luck!
Please vote...........
Jan 15, 2008 | ASUS M2N-MX Motherboard
Cyber Acoustics PC Microphone Not Working Anymore
Well to find out if your computer even recognizes it, you need to right click the white speaker on the bottom right of your computer. Select audio devices. More than likely it will tell you it isn't connected.
I uninstalled the sound completely from my computer. Then i restarted the computer. This will reinstall the drivers for your sound and the one you need for your mic. I have vista but this should still work for XP.
-right click on computer (should be on ur desktop or under start menu)
-select manage
-device manager
-click on the plus next to sound, video and game controllers
-right click on the audio (high definition audio device)
-select uninstall
- restart your computer.
This will do the trick.
your computer should recognize the mic.
Oct 27, 2007 | Cyber Acoustics CV-1064 Microphone
ASUS M2N-MX Motherboard Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
