is the impellor supposed to ride against the pump housing when it is running - because each time i test the pump and then dissassemble it the impellor is no longer tight against the motor it is now extended out against the housing
The fabric softener doesn't seem to be doing anything as far a softening the clothes. Not sure if it...
(More)
The fabric softener doesn't seem to be doing anything as far a softening the clothes. Not sure if it is getting thru the machine properly
After putting a load in, I turn the power on. Then I push the start button. It locks and clicks. ...
(More)
After putting a load in, I turn the power on. Then I push the start button. It locks and clicks. Then it clicks and unlocks after about 5 - 10 seconds. Then 5 - 10 seconds later it clicks and locks again. The water loads but the washer does not spin. It goes through the entire cycle without doing anything but have water in it. There's also a hissing sound when it is supposed to be spinning.
