Kenmore Elite 45986 Front Load Washer
Problem for Kenmore Elite 45986 Front Load Washer
I keep getting an F 02 error close to the end of
By entegra on Nov 04, 2009
I keep getting an F 02 error close to the end of the cycle (rinse/spin) Not sure what the 'white plug out' described by a previous user is can anyone help
Solution #1
posted on Nov 04, 2009
Not Rated)
franktalk
Rank: Guru  Washers & Dryers  Expert
Rating: 87%, 31 votes
f02 means that the water is not drained out after 8 minutes of drain.After removing bottom front plate,you will observe a white filter cap,by removing this cap,you can clean out the filter.Have a shallow pan handy to catch excess water plu towels
Was this helpful?
Yes
No
Solution #2
Not Rated)
jsrock516
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 96%, 7002 votes
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases this means there is a clog in the drain pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 45986 Front Load
Questions and Unsolved Problems for Kenmore Elite 45986 Front Load
Do you recommend Kenmore Elite 45986 Front Load Washer?
Answer
Answer
my detergent drawer will randomly leak out water at the beginning of the wash cycle only. What's... (More)
Answer
f/h flasing during rinse cycle...machine stops but i can reset. what should i change pressure switch
Answer
water stays in softener dispenser tray. The softener is correctly dispersed to the wash (I think)... (More)
Answer
machine is stopped with clothes and soapy water inside. Cannot empty water, complete cycle or even... (More)
Answer
I have an kenmore elite quietpack9 and it's not showing an error code. The time comes up for the dry... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
