Panasonic tv pt-51hx42f shuts itself off and power light flashes 3 times.
Comments:
Nov 04, 2009
- Thank you so much for your quick response. I know you mentioned not continuing to use it, but it wont even let me. Everytime I turn it on it goes right off. Does that change your opinion? Thanks!!
What you might be experiencing based on your symptom sounds like a damaged convergence IC. The three blinks indicates that there is a short holding down the power supply and it is caused by the damaged convergence IC’s. With any Projection Television that has a damaged convergence IC, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set. With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you. While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need. Their site is http://www.andrewselectronics.com/welcome.aspx And their phone number is a 24-Hour Order Desk: (800) 274-4666 I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue. If you need further assistance please comment to this post and I will try to help you further. Thanks for using FixYa asnowman
Comments:
Nov 05, 2009
- Now that it shuts off, you most likley have 3 blinks on the LED. If you don't that still would point me to the STK IC's. They can short out and cause the set to not even power up. I have seen this before, in fact when I get to work on the televisions they are dead most of the time.
The panasonic type 1 convergence repair kit should correct that issue. The kit contains the parts and CD with detailed instructions. You can get it at the following link listed under convergence repair kit. http://servicemanuals.vstore.ca/
tv shuts off on it's own. I have to unplug it and plug it back in to gett it to turn back on. What...
(More)
tv shuts off on it's own. I have to unplug it and plug it back in to gett it to turn back on. What is causing this??
I have a pt-56hxpf panasonic when i turn on no pic the power button just flashes what could be the...
(More)
I have a pt-56hxpf panasonic when i turn on no pic the power button just flashes what could be the problem.
is also doing the power light on then off thing..no blinking tho. what part was replaced for 150.00...
(More)
is also doing the power light on then off thing..no blinking tho. what part was replaced for 150.00 by user theganz5???
